Egine Paint
Page 1 of 1 • Share •
Egine Paint
Looking for input regarding Engine Paint & Primers...better brands that are out there, etc. What have you used and are you happy w/ the results? Input is appreciated! Pics welcomed too.
77mali- 2012 Donating Member
- Street Cred: 14
Re: Egine Paint
Mali - I've always used the Eastwood products with GREAT results, my 59 Cadillac was done in Bill Hirsch paint - very nice results with that as well.
My Laguna gets here next Tuesday (may be at Kitty's Thursday night, weather permitting) - I'll start right away on the engine bay.
Good luck!
Dave C
74 S3 454/4spd
Good luck!
Dave C
74 S3 454/4spd
dcastine- 2011 Donating Member
- Street Cred: 3
Re: Egine Paint
Might have to make that trip to see it. Congrats
Thanks for the tip, I'll check it out @ Eastwood.
Used some Duplicolor engine enamel this evening on my valve covers. I liked the results & they were in bad shape too.
Thanks for the tip, I'll check it out @ Eastwood. Used some Duplicolor engine enamel this evening on my valve covers. I liked the results & they were in bad shape too.
- Street Cred: 14
Re: Egine Paint
On the BBC for my laguna I used POR15 engine paint kit. Sorry can't find a good pic of the color. Good luck, Ron
lagunainnewark- 2012 Donating Member
- Street Cred: 7
Re: Egine Paint
In the 80s I used aircraft paint on a 400 SB. It was Alumi-grip, a two part poyurethane. A few years later, I re-built that engine, and the hot tank at the machine shop didn't even begin to remove that paint. I later decided that that paint may have been making the engine run a bit hotter, even hotter than the usual 400. Maybe it insulated the block some (?) Anyway, I now just use plain engine paint, nothing fussy....
pila- 2012 Donating Member
- Street Cred: 17
Re: Egine Paint
I used Dupli-Color on the motor of my Monte. Turned out great.
Also used it on my old 74 Chevelle, and my dad used it on his 70 Chevelle
- Street Cred: 16
Re: Egine Paint
Are you talking rattle cans?
You can thank the EPA since there are only a few spray paint suppliers left in the USA.
Krylon used to be King back in the day.
NO MORE, Krylon is crapola.
Poor spray, light coverage, crummy nozzles, and it will crinkle in a heartbeat (when the wind blows) for multiple coats, you need at least 24 hours or longer to respray which makes it almost worthless.
My buddy gave me all his left over Eastwood sprays.
They were ok, but I am not sure they are worth the high cost and the ups hazardous shipping charge.
20 bucks for one can and they should be magic.
It’s just paint and nothing special other than the name.
Duplicolor is really good for heat resistant paint specifically for engine paint.
I don't like the nozzles, but for engine durability, you can tolerate crummy nozzles.
I am exclusively using Rustoleum.
Yeah I know, I thought Rustoleum was only used on tractors, but times change.
Coverage, touch-up, multiple coats are easy, availability is everywhere, and cost per can make it my favorite.
I really like Rustoleum satins, hammer tones, and the gloss coverage is good too.
They work well, are tolerant of dirt, have good coverage, have great second coat ability and you can buy it at Walmart for $6 a can.
I sprayed a set of dyno headers with their 2000f heat resistant paint. My buddy used the headers, and the finish resisted a nasty fuel flash fire with no damage to paint surface.
Rustoleum also has an undercoat that has a nice flat even coverage and you can even paint over it with other Rustoleum paints if you don’t like the flat black color.
Thanks -
Thanks -
jerry46765- 2012 Donating Member
- Street Cred: 11
Re: Egine Paint
Duplicolor worked great for me. This was painted 2 Years ago and the only spot it has chipped is the oil pan.
Ghost Rider- 2012 Donating Member
- Street Cred: 3
Re: Egine Paint
I liked how the valve covers came out on mine- except for the "Low -Gloss" black version I used. When dry, It was a bit to flat. I agree w/ Jerry on just about all points w/ the exception of the nozzles on the Rustoleum brand. It seems that depending on where you buy it (at least around here) the nozzles are always different and some of the larger nozzles make my hands tired...i know it sounds a little
but when you do a large area (I did my interior roof/Firewall, etc...) w/ their primers & enamel and while the results were excellent, it was tough to apply. I think here the auto chains have different nozzles than the hardware/home centers...I like the Duplicolor nozzle...the adjustable pattern and the ease of application worked well when I used it on my exterior roof. Think I'm going to go w/ that brand for this application.
- Street Cred: 14
Re: Egine Paint
I think I used Dupli-Color on my 340 engine a few years back and lasted pretty well for the following 4,500 miles until I sold the car. Whatever works!
- Street Cred: 3
Re: Egine Paint
Also wanted to add, that I used VHT on my exhaust manifolds. It's held up fantastically. They still look just as nice as the day they were painted
- Street Cred: 16
Re: Egine Paint
Kyle what the heck is that red bar on the right of your post? I clicked it by accident & it said my vote was cast? For what?
- Street Cred: 14
Re: Egine Paint
77mali, that is a street cred vote. The + shows green, and the - shows red.
If you like a post or the info in it is helpful to you, then you can vote + if you choose. I countered your vote, so you should see both red and green in that bar.
bigredlaguna- G3GM Enthusiast
- Street Cred: 31
Re: Egine Paint
Thanks Bigred. Gonna give all posters some cred. LOL!
- Street Cred: 14
Similar topics» im sneezing red paint again
» Stock Car Evolution Paint Schemes
» FAQ: Riviera Paint Colors/Codes
» Where do i find my paint code....
» Best bus paint job
» K5 Blazer
» 73 CHEVELLE SS PICS
» 75 cutlass
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
