Interior Water Leak...
Page 2 of 2 •
1, 2
Re: Interior Water Leak...
What about putting talcom powder around where you suspect the leak then taking a air hose and blowing from inside. Where you see the puff is where the leak could be.
ant7377- G3GM Senior Member
- Street Cred: 12
Unfortunately it only takes a pinhole to let water drip in. Also, if you used anything but epoxy or a waterproof filler (such as the bond-o green w/ the short fibers) and left it unpainted, water will work it's way through the filler. If it's landing on the seat itself & not the floor boards, chances are it's at the top of the windshield. Lay some plastic sheet in the interior and try to see where it comes in using a cups of water...little by little in different sections of where the roof meets the windshield....may still be a pinhole up there in the channel. Check to see if they filled up to the molding clips, if not then I would try and seal around & up against their work w/ a good quality glass sealant & primer if you still have he moldings off the car. Good luck.
77mali- 2012 Donating Member
- Street Cred: 14
Page 2 of 2 •
1, 2
Similar topics» Is your interior what the Discovery Channel is looking for?
» GSI with oil leak
» Transmission oil seal leak
» water pump oil seal.
» Lidl doing a Water Resistant HD Camcorder
» GSI with oil leak
» 73 CHEVELLE SS PICS
» 75 cutlass
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
