hood clearance
Page 1 of 1 • Share •
hood clearance
I discovered something good for once. The hood on my '75 Elco project will close over the air cleaner. No need for a "bump" etc in the hood.
And that's with a 1" phenolic spacer under the carb too !! weird....
The air cleaner is the stock unit for the '76 Caddy 500 (507) that I have in there. Seems like the original Chevy engine was higher, because the original 350 air cleaner left an imprint on the hood insulation pad.
pila- 2012 Donating Member
- Street Cred: 17
Re: hood clearance
Cool! The less sticking up from the iop of the hood, the more of a sleeper you have. I have tried to keep mine in the sleeper catagory as much as possible, going so far as to buy $1,200 worth of sleeper mag wheels. I took my hood insulation off so my engine could breath just a LITTLE bit better. JB
- Street Cred: 21
Re: hood clearance
My album is not up to date, since my camera is in for repair, but here's the link to my project.
http://s561.photobucket.com/albums/ss52/steelybill/El%20Camino%20resto/
- Street Cred: 17
Re: hood clearance
pila wrote: I discovered something good for once. The hood on my '75 Elco project will close over the air cleaner. No need for a "bump" etc in the hood.And that's with a 1" phenolic spacer under the carb too !! weird....
By the way I checked out the R&R on the photo buckets pics NICE JOB,
2fat2fly- G3GM Member
- Street Cred: 0
Similar topics» Blake Griffin Won the 2011 Slam Dunk Contest via Kia's Hood
» Dana 60 hi steer arm clearance
» Arctic Cat Valve Clearance Specs...
» Hood Clearance
» Hood clearance
» Hood Clearance
» Hood clearance
» 73 CHEVELLE SS PICS
» 75 cutlass
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
