Upper ball joints
Upper ball joints
Post by wokrdan AKA BU Balls on 14/10/2011, 14:08
I'm installing new upper ball joints and can't figure out if the rubber boot goes on the knuckle before it goes into the control arm, or on the bottom side in the metal housing piece. Anyone know?
Street Cred: 2
View user profile
Re: Upper ball joints
Post by 1973 454 MONTE on 14/10/2011, 17:01
just put uppers on mine.the boot goes under the a-arm.
2012 Donating Member
Street Cred: 26
View user profile
Post by pila on 14/10/2011, 19:05
Yeah, the stud on the ball joint goes through the boot, then into the spindle. The boot of course, retains the grease & seals it from dirt.
Street Cred: 17
View user profile
Post by Fishgrinder on 15/10/2011, 12:48
I was wondering about this as well and put it inside the metal housing. It just seemed most logical to put it that way to me.
But should it be on the outside, as you say "under " the A-arm 1974 454 Monte? Is there really a big difference between the two?
Original seems to be inside as well, it's a one piece though (right?)
Fishgrinder
Street Cred: 0
View user profile
