Oil Pressure Help
Page 2 of 2 Previous  1, 2
Re: Oil Pressure Help
Post by prostreet75 on Mon Oct 17, 2011 2:59 pm
Ghost Rider wrote:Maybe just need to keep my size 12 out of the gas some? GoFast
Well that's no fun. Laughing
prostreet75
Street Cred: 0
View user profile
Post by Ghost Rider on Mon Oct 17, 2011 3:24 pm
Top picture is the one that is blowing the oil through.
Ghost Rider
2012 Donating Member
Street Cred: 3
View user profile
Post by prostreet75 on Mon Oct 17, 2011 3:50 pm
Ghost Rider wrote:Top picture is the one that is blowing the oil through.
Try a PCV valve. It'll work great. Its super cheap to do, and if you don't like it, you won't be out but a couple dollars. Just plumb it into the large vaccum port in the base plate of the carb. The edlebrocks are in the front and the Holleys are in the back. If you don't have that opition, and you have a spacer plate under the carb, you can always drill and tap that in the rear, and put in a nipple for the hose to connect to.
prostreet75
Street Cred: 0
View user profile
Post by prostreet75 on Mon Oct 17, 2011 3:52 pm
This is my old setup that shows the PCV.
[img][/img]
prostreet75
Street Cred: 0
View user profile
Post by pila on Mon Oct 17, 2011 9:04 pm
Seems like the drain-back holes on each end of the heads should be able to get the the oil off of the tops of the heads. Should be a reason that there's that much oil up there, that it can be pushed out. (?)
Maybe not the reason here, but some blocks partially cover the drain back holes in the rear of the heads. Found that on two different engines.
Street Cred: 17
View user profile
Post by Ghost Rider on Tue Oct 18, 2011 5:31 am
Think I am going to try the PCV. Getting tired of throwing money at it. I can always go to the catch can later.
Ghost Rider
Street Cred: 3
View user profile
Post by prostreet75 on Tue Oct 18, 2011 8:56 am
Sweet. Let me know how it works.
prostreet75
Street Cred: 0
View user profile
