Cutlass Wheel Bearings
Page 1 of 1 • Share •
I had my truck setting for a few weeks while I did some maintenance on it, so I drove my 77 Cutlass to work for about 6 weeks. It was fun but listening to a Pete Jackson gear drive for 1-1/2 hours a day can tend to wear on you after a while.
Anyway, last Friday while driving into work I noticed a slight pull on the steering wheel and started hearing something that sounded like I had a box caught between the tire and the wheel well. Then I started noticing a vibration on the left floor board. I shook it off and continued on.
The noise was still there on the way home. Once home, I grabbed the top of the both tires and pulled. I could feel some play in the right wheel but none in the left. I figured I would just repack the bearings quick. I needed the car to go to work again on Saturday morning. I repacked the right side, thought the bearings could stand to be replaced, but put it back together. It was getting late by this point and I almost didn't do the left wheel, but went ahead and tore into it. This is what I found
Digging deeper I took the bearing out in pieces
Luckily I caught it in time before it damaged the spindle.
So, the next morning I took the wife's car to work. I couldn't believe it that Advance Auto had rotors, bearings, and seals for a 1977 Cutlass. There were quite a few parts I had to wait for from them for '06 Silverado. Go figure...
itis34- G3GM Newbie
- Street Cred: 0
Re: Cutlass Wheel Bearings
Jeez....makes me want to inspect mine. Good thing U caught that.
77mali- 2012 Donating Member
- Street Cred: 14
Lucky you checked it and caught it in time.
w451973- G3GM Member
- Street Cred: 0
Advance auto seems to have about anything I need for A body years.
pila- 2012 Donating Member
- Street Cred: 17
Similar topics» PCD WHEEL CHART
» FS Momo Mod 88 Steering Wheel and adaptor.
» Anlasser-Freilauf / Starter free wheel
» super custom 4x4 front wheel bearings
» Front wheel bearings for a KZH120
» K5 Blazer
» 73 CHEVELLE SS PICS
» 75 cutlass
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
