Idiot Light to Gauges Conversion
Page 1 of 2 1, 2  Next
Post by Mcarlo77 on Mon Nov 21, 2011 10:10 am
Can't remember if this has been discussed here, but has anyone done the dash cluster idiot light to gauges conversion on a Chevelle/Malibu/Monte Carlo? I know the flex circuitry behind the two styles of clusters is different...but, does it require replacing the entire underdash and engine bay wiring harnesses? I also know there is a separate pigtail wire out to the engine for the tach. Question came up over the weekend and would appreciate any info.
2012 Donating Member
Street Cred: 17
View user profile
Re: Idiot Light to Gauges Conversion
Post by Mcarlo77 on Tue Nov 22, 2011 9:38 pm
Wow...that's a whole lotta splicing. I think I'd be inclined to just find a complete wiring harness designed for tach gauge cluster and save myself alot of headaches.
Street Cred: 17
View user profile
Post by 1973 454 MONTE on Tue Nov 22, 2011 9:54 pm
Mcarlo77 wrote:Wow...that's a whole lotta splicing. I think I'd be inclined to just find a complete wiring harness designed for tach gauge cluster and save myself alot of headaches.
i did it to my 73. i had the gauges and the under dash harness. i bought an NOS engine harness off ebay and took a weekend and did it.
Street Cred: 26
View user profile
Post by Mcarlo77 on Wed Nov 23, 2011 9:46 am
So...aside from the special Tach wire that runs out to the distributor, you DO need a different engine bay harness?
Street Cred: 17
View user profile
Post by 1973 454 MONTE on Wed Nov 23, 2011 6:43 pm
i bought the NOS engine harness because it had 2 plugs for the power to the distributor. i did not want to run points and could not find the original harness that went with the dash and harness. Head Bang
i have boxes of harnesses from over the years,but have never sat down and figured out what they are. the only clue i have is 73s were 2 piece harnesses under the dash. the rest is a blur to me Crying or Very sad
Street Cred: 26
View user profile
Post by 77mali on Wed Nov 23, 2011 6:58 pm
I have a 73 Harness from a Monte Shocked. It was out of a car that had a TH400 & power windows & locks. There is a separate square "piece" that a bunch of wire go into similar to the fuse box (but no fuses) that mounts to the firewall behind the radio somewhere. I remember one of the wires clips onto the deluxe style gas pedal. It's much different than the one on my Malibu in terms of the amount of wires. I may end up using it to convert to the round gauges which I also snagged at the time...but they are the idiot lights so I plan to go with some after market gauges in their place & get ride of the clock for a 2" tach in that spot. I'm still debating all of this & it's not gonna happen till some funds open up. I think I'd go nuts if I had to splice all those wires.
Street Cred: 14
View user profile
Post by 1973 454 MONTE on Wed Nov 23, 2011 7:26 pm
Street Cred: 26
View user profile
Post by 77mali on Wed Nov 23, 2011 7:36 pm
Man that's a lot of wires! LOL. I don't remember the piece that's crossing under the column in your pic being there...what's that connection for?
Street Cred: 14
View user profile
Post by texan01 on Wed Nov 23, 2011 7:51 pm
You could just swap the wires around in the harness at the pc board.
That's what I'm going to do whenever I get around to installing my gauge setup. i need to fix the bezel I have since a corner is broken off. I got a piece from another broken bezel to piece into it. then find woodgrain to put on it.
texan01
Street Cred: 5
View user profile
Post by 1973 454 MONTE on Wed Nov 23, 2011 7:58 pm
77mali wrote:Man that's a lot of wires! LOL. I don't remember the piece that's crossing under the column in your pic being there...what's that connection for?
thats the wires for my A/M gauges. (negative and light wires)
Street Cred: 26
View user profile
Post by 1973 454 MONTE on Wed Nov 23, 2011 8:03 pm
i have some nice bezels with woodgrain. most of mine are black because they came off of 73's. in 74 the bezels became color coded to the dash.
Street Cred: 26
View user profile
Post by Mcarlo77 on Wed Nov 23, 2011 10:06 pm
Was gonna say...bezels aren't that hard to find in nice condition and they aren't that expensive.
Okay...so, had some time today and, just to satisfy my curiosity, I decided to run down to the local U Pull and pick the underdash harness off the '75 Laguna sitting down there. This car had the gauges, but not the tach. Instead, it had the Fuel Economy gauge. Would this be the same harness as used with the tach...except for the tach wire that runs out to the distributor?
Street Cred: 17
View user profile
Post by 77mali on Thu Nov 24, 2011 7:46 am
I have heard that the tach & fuel econ gauge are easily interchangeable and have the exact same "pod" for the gauges to sit in.
Street Cred: 14
View user profile
Post by Mcarlo77 on Thu Nov 24, 2011 9:21 am
That much is correct. Just wondered if there were any differences in, say, the back illumination bulbs, etc. Don't really think so...
Street Cred: 17
View user profile
