differences between tach and econo gauge clusters
Page 1 of 1 • Share •
73 tach front
76 econo front
73 tach back
76 econo back
76 econo front
73 tach back
76 econo back
- Street Cred: 26
Re: differences between tach and econo gauge clusters
I changed my 76 Laguna over to a tach, If I remember correctly, I added a inserts for the tach and ran the wire to the distributor. I can check the prints and my spares If you need, Ron.
lagunainnewark- 2012 Donating Member
- Street Cred: 7
From what I could see on the '75 Laguna w/tach in the salvage yard vs the '76 Laguna w/Economy gauge, the underhood wiring harness from the junction block on the firewall is the same. The required tach wire, though, runs through the firewall along with the wiring for the A/C-Heater harness. What I'm unclear about is whether this tach wire, which appears to be bundled up inside the main underdash harness, runs to the back of the tach...or, runs into the muti-wire connector behind the speedo? In short, can you utilize the same underdash harness (as with the Econo gauge) and just add the tach wire out to the distributor?
Mcarlo77- 2012 Donating Member
- Street Cred: 17
The only diff I see is the vacuum port on the rear of the pod for the economy gauge. I think the tach has to connect to the HEI as well as somewhere on the fuse box. Wonder if the box has a dedicated slot for "Tach"? I have a 73 monte harness but my cluster is the large gas gauge w/ speedo but I'll look to see if there is one on non-equipped anyway.
77mali- 2012 Donating Member
- Street Cred: 14
77mali wrote:The only diff I see is the vacuum port on the rear of the pod for the economy gauge. I think the tach has to connect to the HEI as well as somewhere on the fuse box. Wonder if the box has a dedicated slot for "Tach"? I have a 73 monte harness but my cluster is the large gas gauge w/ speedo but I'll look to see if there is one on non-equipped anyway.
- Street Cred: 26
The power and grounds are already in the circuit board, add the tach wire to the main connector then to the distributor. You can trace the track lines on the circuit board to find the correct pin position. Let me know if you need more info, Ron
- Street Cred: 7
That's what I wanted to know, Ron...thanks for the pics and info!
- Street Cred: 17
No problem, anything to help. Ron
- Street Cred: 7
1973 454 MONTE wrote:77mali wrote:The only diff I see is the vacuum port on the rear of the pod for the economy gauge. I think the tach has to connect to the HEI as well as somewhere on the fuse box. Wonder if the box has a dedicated slot for "Tach"? I have a 73 monte harness but my cluster is the large gas gauge w/ speedo but I'll look to see if there is one on non-equipped anyway.
I see why now, the 73 has an amp gauge and the other a voltage gauge. Very curious thing.
- Street Cred: 14
GM made the same change in the trucks also. From personal experience, I've seen the dash melt from the current through the amp gauge. I also think they did it to save $$$. Ron
- Street Cred: 7
Similar topics» Standard Instruments to Tach 1970 Mach 1
» differences between tach and econo gauge clusters
» FS: BNIB Sunpro triple gauge cluster - TN, USA
» Interior lights & gauges not working
» SOHC to DOHC gauge cluster
» EGR
» 1974 Chevelle Malibu for Sale
» 76 S3 in Franklin Indiana
» New New Yorker
» NO...NO...NO...
» '77 Malibu in Progress
» K5 Blazer
» Just some pics
» 75 MALIBU CLASSIC FROM EL PASO TX
