anybody ever messed with a monza??
Post by maliburacinfreak on Mon Dec 12, 2011 12:06 am
i might be trading my 84 regal for one. its an 80 notchback, fresh .030 over 231, eddy intake, holley carb, th350 w/shift kit, posi 3.08 rear. solid car with very little rust. pretty cool little car. ill try to post pics tomorrow. anything i should look out for on this car?
maliburacinfreak
2012 Donating Member
Street Cred: 5
View user profile
Re: anybody ever messed with a monza??
Post by Limey SE on Mon Dec 12, 2011 7:17 am
shock tower rust or damage front and rear ............and the where the unibody meets the frame they like to twist there
Street Cred: 60
View user profile
Post by maliburacinfreak on Mon Dec 12, 2011 8:52 pm
pics!
maliburacinfreak
Street Cred: 5
View user profile
Post by jerry46765 on Tue Dec 13, 2011 10:43 am
Yep, I had one; a '77 Spyder 4-speed car.
That is one I would like to have it back.
They are unibody cars, and they rust everywhere.
Your car has 5 lug wheels which isn't standard but would make tire and wheel selection lots easier.
Since you have the v6, you won't have the service headaches of the cramped v8.
The first set of headers I ever installed was on a v8 Monza. All other installs are easy after that one.
Looks like a nice car. Enjoy it.
Thanks -
Street Cred: 11
View user profile
Post by Biomedtech on Tue Dec 13, 2011 8:00 pm
Helped a buddy of mine shoehorn a 454 into one back in 84, after he put a tube frame under it.... Had just enuff room between the rear wheeltubs to mount the baby seat! LOL
Biomedtech
Street Cred: 2
View user profile
Post by ant7377 on Tue Dec 13, 2011 9:23 pm
My friend had one in HS . THe friggin thing leaked water through the stupid pop up sunroof like a sieve. No offense but i hated that car.
Street Cred: 12
View user profile
Post by badbiscayne66 on Sat Dec 17, 2011 3:06 pm
VEGA in disguise!!!!
badbiscayne66
Street Cred: 2
View user profile
Post by pila on Sat Dec 17, 2011 4:28 pm
I picked up an '80 Sunbird for my youngest son. Pretty much the same as a Monza. It had the 231 & TH350 in it. Had to replace the heater core........removed the whole dash to change it. It's a uni-body car. Did a valve grind on the engine. The oil pump needed replacement, since the oil light would blink at idle sometimes when the engine was hot. The electric fuel pump won't work if the oil pressure gets too low, since I believe it's powered through the oil pressure switch, which runs the oil light.
This one had a lot of zip for a V6. Only thing is, if the oil pressure gets to be a problem, replacing the timing cover is necessary, since the pump gears run in it, as part of the pump. When the housing wears, new pump gears are a band-aid fix, which doesn't help much.
I had an '84 Regal Limited, which had the same 231 engine, and it also needed new pump gears once, which seemed to work OK.
Street Cred: 17
View user profile
Post by knightfan26917 on Sat Dec 17, 2011 6:46 pm
Wow ... that Monza looks good!
* Radio.HolidayCDshowcase | 12.24.2011 | Noon-4p.CENTRAL | www.wrmn1410.com *
"I don't know if there'll be snow" __ Burl Ives __ 'Have A Holly Jolly Christmas'
2011 Donating Member
Street Cred: 3
View user profile
Post by maliburacinfreak on Sun Dec 18, 2011 6:26 pm
thanks guys. the trade should go down this coming wednesday, when we both have a day off. hopefully i shouldnt have any oil pump issues as the motor is fresh with very few miles on it. at one time, the guy had an early carb'd GN motor in it. but something was wrong with the wastegate and once it would build 22psi, it broke ring lands in the cast pistons. after doing that twice, he built the n/a motor for it.
maliburacinfreak
Street Cred: 5
View user profile
