Wiring help needed: rear defogger and switch
Post by gpoetx on Wed Jan 11, 2012 1:09 pm
So I want to add the defogger and switch to my sons 1974 Laguna. I have the unit and switch, what I can't find is a diagram. Does anyone have a diagram or at least point me the way to wire this up. Not sure if there is a relay or where the 3 wiring ends from the switch go. Thanks for any help.
Gary
gpoetx
Street Cred: 0
View user profile
Re: Wiring help needed: rear defogger and switch
Post by 1973 454 MONTE on Wed Jan 11, 2012 4:31 pm
i have a harness. will try and get pics.
2012 Donating Member
Street Cred: 26
View user profile
Post by thatfnthing on Fri Jan 20, 2012 12:51 pm
FWIW, from the Monte Carlo:
- Pink 16ga wire from fuse box ACC tap to center terminal of the defog switch, but with a 4A inline fuse along the way
- Purple wire from switch runs directly all the way back to the fan. This feeds full 12V to fan for high speed.
- Yellow wire leads to white resistance wire, which then splices into purple wire. This reduces voltage to provide low speed. If you don't have the resistance wire, you can probably splice in an actual resistor, but I don't know what the value should be.
Mark
Street Cred: 9
View user profile
Post by gpoetx on Fri Jan 20, 2012 2:10 pm
Appreciate it, I think just to be simple I'm going to make it Hi/Hi and skip the low.
gpoetx
Street Cred: 0
View user profile
