My '73 build long project
Page 4 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
My '73 build long project - Page 4 Empty Re: My '73 build long project
Post by Trbulnc on Fri May 31, 2013 2:52 pm
Still lack 2 frame braces and driveshaft loop but with humidity time coming wanted to get it sealed.
Trbulnc
Post by Trbulnc on Fri May 31, 2013 2:58 pm
My '73 build long project - Page 4 5D8ACBC0-37CC-41A2-B041-9323D791BD12-13124-000006A15F0BB48E
Rear shocks mounted. Can easily remove and run a full coil over if I wish instead of air bags.
Trbulnc
Post by Trbulnc on Fri Jun 21, 2013 4:16 pm
My '73 build long project - Page 4 5D37E093-6C4E-408A-A737-7797E6F63C24-183-0000004ECD919421
My '73 build long project - Page 4 7A845D07-60DC-4E85-958E-6EF3EC8D1A5E-183-00000050B9295B28
Pic of getting it all aligned and tack welded for fit up.
Frame is on the ground.  Still have some small stuff to finish but getting close to being ready to go back under the body. Front will lay to within 2 1/2" to ground at crossmember lowest point.  Bags aren't all the way flat so with more weight prob a little lower.  Will post some top and side view pics this weekend.
Trbulnc
Post by Trbulnc on Fri Jun 21, 2013 8:17 pm
My '73 build long project - Page 4 6E2A4E27-2933-4C79-95DE-FCA0F0E4AA61-868-00000087B4FC1DBB
My '73 build long project - Page 4 7B5F40E3-F54D-4E50-BD01-72463E49B3A4-868-00000087A2DEFF74
My '73 build long project - Page 4 93DF1D58-0F55-49C7-BA0F-15DCF108EC38-868-000000879A6ACC20
Trbulnc
Post by Trbulnc on Fri Jun 21, 2013 8:20 pm
My '73 build long project - Page 4 4B21F734-A4F6-4C50-8DDD-F3639F1DA1B1-868-0000008967CE334B
Trbulnc
Post by 77mali on Fri Jun 21, 2013 8:52 pm
Whoa...that's a whole lotta sweat equity.
Beer
Post by Trbulnc on Sun Aug 11, 2013 7:12 pm
Been a while so I'll throw up some pics. Body is back in, have a few small things to redo I can see. Got lots of sheet metal work now moving rear tubs in.
My '73 build long project - Page 4 C4A52F11-FC39-40DE-8296-91089C775D72-6908-000003183D58F4F3
My '73 build long project - Page 4 779D18EA-4224-4E38-919B-8142A23367AE-6908-00000318454CB52A
My '73 build long project - Page 4 FAEA9D9B-998C-4893-953E-91B816ACA346-6908-000003184D268A61
My '73 build long project - Page 4 981E1224-8D7F-4751-98E3-62CB3F3B6376-6908-0000031854070231
Trbulnc
Post by Trbulnc on Thu Nov 21, 2013 11:52 am
My '73 build long project - Page 4 118ED7E5-8C78-4030-BCE9-D623232B3305
My '73 build long project - Page 4 102108A7-00E0-4373-9863-592FD81F6C87
My '73 build long project - Page 4 78566F45-311C-4216-9E7F-F3A1D89970BC
Few overdue pics. Didn't like the way it was sitting so changed stuff all around on 4 link and got a height I am happy with now. Any lower and driveshaft tunnel will need to be modified and tire will touch quarter. Other pic is ride height, body not mounted so it looks crooked. Next is plumbing all the air, them patch some floors. Goal is be ready for final sanding/prep for paint by spring.
Trbulnc
Post by Trbulnc on Thu Nov 21, 2013 11:54 am
And that is only a 15" rim so it will look better with an 18. Working trunk pan area also so it will hold a 13" wide rim.
Trbulnc
Post by Trbulnc on Mon Nov 25, 2013 3:01 pm
Ordered new trunk panels last night, started laying out tank and other stuff as well as plumbing some air lines. Have some time off on holidays so hope to burn some metal.
Trbulnc
Post by driveit on Mon Nov 25, 2013 4:37 pm
I am Excited to see your progress. Have you chosen what wheels and tires you are going with yet?
Post by Trbulnc on Mon Nov 25, 2013 7:10 pm
My '73 build long project - Page 4 61712FE5-3A57-4217-ABC0-99B75E77D209
My '73 build long project - Page 4 5CFAB029-02D0-4CC3-B918-ED41BCE23DF0
Kinda torn at the moment between these two but leaning toward the silver to match the color scheme
Trbulnc
Post by thatfnthing on Mon Nov 25, 2013 9:11 pm
That already looks sweet even with the beater wheels.
Street Cred : 58
Post by driveit on Tue Nov 26, 2013 8:20 am
Dude, I am lovin those top ones!!! I was thinking about going with a more modern style wheel myself, but it seems that they are so much more expensive. Whatever I was to get would probably have to be under 200 each and the cheaper the better. Got a link to those on the top?
Post by 77mali on Tue Nov 26, 2013 8:32 am
I like the old Buick (?) rims. Very Happy Them fancy schmancy ones are nice too (1st pic).
Lookin' good.
Post by dynchel on Tue Nov 26, 2013 9:11 am
77mali wrote:I like the old Buick (?) rims.  Very Happy Them fancy schmancy ones are nice too (1st pic).
Lookin' good.
Those are keystone klassics complete with unilug mounting holes.
Post by Trbulnc on Tue Nov 26, 2013 1:10 pm
http://www.nutekwheels.com/p-92-series-508.aspx
Wheel link.
Yup, old keystones. Were on the car when I bought it and rolled them all these years.
Trbulnc
Post by driveit on Tue Nov 26, 2013 4:28 pm
I like the 710 Step-lip Concave. Not sure if it would fit or not, but I know it wouldn't fit my budget at around 1200 per wheel.
Post by Trbulnc on Tue Nov 26, 2013 4:44 pm
I didn't see a price. Was afraid to look too deep
Trbulnc
Post by Trbulnc on Fri Dec 13, 2013 10:41 am
Few new pics, working on the new trunk pan and mini tub. Studied it for a while and decided easiest to do was take a sawzall and cut it all out and work from there. Drilled the spot welds all out on support rails and cleaning them up. Will weld them back in first and have something to attach the trunk pan when going back together. Hope to knock this out over the holidays. The new trunk panels fit surprisingly well.
My '73 build long project - Page 4 65124CD9-DD34-4975-B819-62EBA9BF9611
My '73 build long project - Page 4 59E6CCC6-91EA-409D-8ACF-57E3AFC93800
My '73 build long project - Page 4 95438057-F2E5-4D31-AFF7-BCEA656F01A7
My '73 build long project - Page 4 E1561EAE-8AAF-4DF4-9D30-D83F95FB2E67
My '73 build long project - Page 4 355AFE5C-ACE8-4D4F-97E5-59C327485130
My '73 build long project - Page 4 0B94907F-C993-40F4-A6DC-E2D46E954C04
My '73 build long project - Page 4 8C488D36-EA53-4105-82C0-E5ADCB2865B5
Trbulnc
Post by dynchel on Fri Dec 13, 2013 9:38 pm
Looking good.  That is a project I will have to do eventually.   Rolling Eyes
Post by driveit on Sat Dec 14, 2013 8:18 am
That looks good. I looked at my truck the a month or so back and found a small hole. The trunk was always solid, but it had been sitting for over 6 years.
Post by 77mali on Sat Dec 14, 2013 9:34 am
Nice job.
Post by Dinomyte on Fri Dec 27, 2013 3:03 pm
Wow ! Nice work. I'm newish here and been reading some of the other threads as I've got time. This is impressive. When did you start this project?
Post by Trbulnc on Sat Dec 28, 2013 12:18 am
Thanks. I'm two years into it as I have time. Sometimes life happens and it sits for a bit. Should have the trunk pan finished in another week. Been welding and grinding and fitting last week getting it all lined out. Will have more pics soon.
Trbulnc
