Found a camshaft!!!
Found a camshaft!!! Empty Found a camshaft!!!
Post by wokrdan AKA BU Balls Fri Jan 27, 2012 11:22 am
So after a few weeks of research, I've decided to go with the Edelbrock Torker camshaft.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__5027209-P_1279_N%7CGRP60011____
I know I need to get a new timing chain, springs, and pushrods, and here's what I've found:
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__5027527-P_166_N%7CGRP60010____
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__5020131-P_173_N%7CGRP60011____
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__22342651-P_3049_N%7CGRP60011____
I've got a discount code for $50 off purchases over $150 through Advance Auto, so I'm splitting it up into two orders, so essentially getting $375 worth for $275. Does anyone know of anything else that would need to be purchased that I might be forgetting? (I already have a 4 bbl Edelbrock carb I plan on reusing and am going to get a new intake manifold a little later down the road)
Found a camshaft!!! Empty Re: Found a camshaft!!!
Post by pila Sat Jan 28, 2012 2:25 am
What pistons are you using ? The compression ratio will need to be above 9 or so to 1, or that cam will not perform. You may want to email or call Edelbrock or even Summit Racing tech line, before buying that one. If you have stock 8.5 to 1 CR, that's too much cam I believe, and will not add much or any power.
Post by 2fat2fly Sat Jan 28, 2012 9:10 pm
wokrdan AKA BU Balls wrote:So after a few weeks of research, I've decided to go with the Edelbrock Torker camshaft.
IF YOUR RUNNING AN AUTO TRANS. YOU'LL NEED A 2200-2500 STALL CONVERTOR, TIMING GEAR SET DOES NOT MATTER ( HEADS UP ON THE MARKS THOUGH) IF I WERE YOU I'D STEP UP ON THE SPRING PRESSURE BY 100, HYD. TAPPET CAMS LIKE THAT IF YOU WON'T TO BE ABLE TO REV..?????????????!!!!!!!!!!!!!!
2fat2fly
2fat2fly
