BOTH TAIL LIGHTS FLASH WHEN LEFT SIGNAL IS ON NEED HELP
G3GM :: G3 Tech :: Electrical
Page 1 of 2
I AM WORKING ON MY 75 LAGUNA AND CANT GET THE SIGNALS TO WORK RIGHT NOW WHEN I TURN ON MY LEFT TURN SIGNAL IT WORKS IN FRONT BUT IN BACK BOTH SIDES R FLASHING .. ANY HELP WOULD BE APPRECIATED..
laguna55- G3GM Member
Re: BOTH TAIL LIGHTS FLASH WHEN LEFT SIGNAL IS ON NEED HELP
Did you mess with the wiring harness back there ? It sounds like something is connected wrong.Do you have a wiring diagram? There is three wires going to each socket back there.The power goes to the left side first maybe something is touching around there that could trigger the right side light.
make sure you have all 1157 bulbs in the sockets. a 1156 bulb only has one pin and if put in to a 1157 socket will short it out.
if you need new bulbs put in 2357s they are brighter
Any splices or tears in the line? Was it ever unconnected from the forward harness?
77mali wrote:Any splices or tears in the line? Was it ever unconnected from the forward harness?
NO JUST BEEN WORKING ON THE DASH PANEL
1973 454 MONTE wrote:make sure you have all 1157 bulbs in the sockets. a 1156 bulb only has one pin and if put in to a 1157 socket will short it out.
OK WILL CK THAT AND PUT NEW ONES IN
ant7377 wrote:Did you mess with the wiring harness back there ? It sounds like something is connected wrong.Do you have a wiring diagram? There is three wires going to each socket back there.The power goes to the left side first maybe something is touching around there that could trigger the right side light.
NO ITS ALL STOCK I WILL CK THAT OUT TO THANKS
If you messin under the dash take a look at the fuse box make sure that big bolt (engine compartment side) is tight (dont break it) and the wires coming from there arent pinched or cut /shafed.
Sounds like bad ground. Try grounding to bumper with jumper cables. At least that will tell you where to start.
Tom77- Donating Member
Ghost Rider wrote:Sounds like bad ground. Try grounding to bumper with jumper cables. At least that will tell you where to start.
There are a few grounds under there that go into the lower dash section and there is one in particular that is on the lower door pillar, drivers side that grounds the door wires for the dome lamp & also includes wires that go to the rear harness through the plastic channel along the rocker. Check there.
still havent got it fixed try to ground the batt. ,, looked under dash and all looks ok to me the right front signal is weak maybe it is on that side
Sometimes the bulbs are defective-especially today with china quality. Maybe replace them-cheap enough and see what happens,could be the wires in the sockets are corroded too.Just look closely at the harness both front and back I still think you have a broken wire someplace.Try using a test light and drag it along the wires and see if it lights up-with the lights on of course so you have power at the circuts.
I'm no electrical engineer, but seems to me that if the hazard lights, right turn signal lights, brake lights, driving lights all work as they should, the problem could be in the turn signal switch?
Bad grounds can make strange things happen sometimes. I've seen dash lights come on with the brakes ! weird..If a dual filiment lamp doesn't have a good ground on one side, it will sometimes back-feed to get a ground from the other side of the lamp, and will be half lit.
The grounds in GM cars, under the dash, are a trouble spot over the years. On the left side of the dash bottom, the bolt/screw that attaches the dash bottom to the door post, which is used as a ground sometimes, can get loose, making for crazy things to happen.
Mcarlo77 wrote:I'm no electrical engineer, but seems to me that if the hazard lights, right turn signal lights, brake lights, driving lights all work as they should, the problem could be in the turn signal switch?
I HAVENT TOOK THE WHEEL OF YET TO CK THE SWITCH . WILL TRY THAT
pila wrote:Bad grounds can make strange things happen sometimes. I've seen dash lights come on with the brakes ! weird..If a dual filiment lamp doesn't have a good ground on one side, it will sometimes back-feed to get a ground from the other side of the lamp, and will be half lit.
WILL CK THAT TO , I HAVE PUT electrical GREASE IN ALL OF THEM ALSO ,,
I have to agree with "Mcarlo77" if all else is in order !!!!!!!!!! and the bleed only comes when activating the switch, could it be ??Mcarlo77 wrote:I'm no electrical engineer, but seems to me that if the hazard lights, right turn signal lights, brake lights, driving lights all work as they should, the problem could be in the turn signal switch?
the hazard, brake and right tun lights all use the hi side filament
you just might try another flasher though, couldn't hurt
2fat2fly- Donating Member
i got it fixed it was the switch behind the steering wheel the last thing it cked. thanks for all the help i would have never ck it if it wasnt for you guys ,,, now to get my alt charging ,, i have a good alt. 3 wire post on back is to the + on battery then i have the #1 #2 plug on side of alt i think i have the #2 wire going to the back of alt that gos to the + of battery the #1 wire i dont know where to put it. and for a bonus i dont have a meter to ck it .. any ideas
Was it a loose wire in the switch? Here's how mine is connected @ alt, hope it helps.
77mali wrote:Was it a loose wire in the switch? Here's how mine is connected @ alt, hope it helps.
yes it was all loose and comeing off
the pic helps a little where dose the red wire go to that comes out the white plug ,, the brown one gos to the alt light in dash
All three of the wires in the pic go into a junction in the main harness (T). I have not disconnected the harness so, I can't tell you where they end up, sorry. The plastic conduit splits in the rear of the engine and mine is a double junction w/ 2 of the T's. There are several Red wires that go to A/C, fusible link & heater stuff but eventually the harness goes all the way back to fuse junction box. It also leads in other directions for other systems (starter, battery lead, etc). Is yours the original harness? to the car?
laguna55 wrote:now to get my alt charging ,, i have a good alt. 3 wire post on back is to the + on battery then i have the #1 #2 plug on side of alt i think i have the #2 wire going to the back of alt that gos to the + of battery the #1 wire i dont know where to put it. and for a bonus i dont have a meter to ck it .. any ideas
The fat red wire going to the battery or starter connects to the post on the back of the alt -- this is the main power feed. For the connector, the brown wire goes to the gen/alt light in the dash, and the red wire goes to the ignition switch -- the alt uses this wire to sense system voltage so it knows how much juice to put out.
Mark
LOL...
Sorry, thought the pic would be self explanatory but yes it is to the nut right next to it in the pic. (Thanks thatfnthing) Was over-thinking the question
77mali wrote:All three of the wires in the pic go into a junction in the main harness (T). I have not disconnected the harness so, I can't tell you where they end up, sorry. The plastic conduit splits in the rear of the engine and mine is a double junction w/ 2 of the T's. There are several Red wires that go to A/C, fusible link & heater stuff but eventually the harness goes all the way back to fuse junction box. It also leads in other directions for other systems (starter, battery lead, etc). Is yours the original harness? to the car?
yes it is the original one
77mali wrote:LOL...
no you were right i need to know where it gos to the fire wall thats my prob.
Page 1 of 2
