Oil Pan Selection - Help
Biomedtech
Guys - I need help picking out an oil pan with increased capacity. Here's my problem. I need it to clear both the passenger side Hooker Super Comp header and not hang lower than the motor crossmember. I would just take some measurements of the current one in the car, but it's NOT in the car right now. The motor is being torn apart as I type, and I have no way of taking measurements on it.
Does anyone have any measurements of the distance from the rear of a stock oil pan to the back of the cross member? Also, maybe a measurement of the distance between the headers perpendicular to the oil pan? Or even some photos? I looked through all of mine, but don't have any photos from under the motor?
Any help would be greatly appreciated!
74Malibu383- Donating Member
Re: Oil Pan Selection - Help
Could you go with a dry sump and external tank like these?
http://www.milodon.com/oil-pans/circle-track-dry-sump-pans.asp
Biomedtech- G3GM Member
I don't think I want to go the dry sump route right now. 2 grand on an oiling system seems a bit much even if it's a great way to go.
If anyone just has a photo of thier stock oil pan while in the car, it would help me out.
THANKS! So close to what I'm looking for! Would you be able to get one showing how much room is beteen the front of the pan and the back of the crossmember?
Bryan - I'll try to get one tomorrow morning.
This was on my Chevelle.
The pan on my Malibu is a Moroso 6 quart, and is even with the bottom of the front cross member, 8 1/2 inches deep.
74Malibu383 wrote:THANKS! So close to what I'm looking for! Would you be able to get one showing how much room is beteen the front of the pan and the back of the crossmember?
Hows this?
BIG BLOCK OR SMALL BLOCK, NEED TO KNOW74Malibu383 wrote:Guys - I need help picking out an oil pan with increased capacity. Here's my problem. I need it to clear both the passenger side Hooker Super Comp header and not hang lower than the motor cross member. I would just take some measurements of the current one in the car, but it's NOT in the car right now. The motor is being torn apart as I type, and I have no way of taking measurements on it.
2fat2fly- Donating Member
His is a SMALL BLOCK.2fat2fly wrote:BIG BLOCK OR SMALL BLOCK, NEED TO KNOW74Malibu383 wrote:Guys - I need help picking out an oil pan with increased capacity. Here's my problem. I need it to clear both the passenger side Hooker Super Comp header and not hang lower than the motor cross member. I would just take some measurements of the current one in the car, but it's NOT in the car right now. The motor is being torn apart as I type, and I have no way of taking measurements on it.
Malicruiser- G3GM Member
GO TO SUMMIT AND PICK OUT WHAT YOU NEED, MILODON MAKES A CRAP LOAD OF PANS THAT WILL WORK, I HAVE THE BB 31555, WITH THE KICK OUT ON THE BOTTOM, AND NO PROBLEMS WITH R&R ON THE STARTER AND I HAVE THE SUPER COMP.HOOKER HEADERS. YOU'LL HAVE TO PUT THE MOTOR IN FIRST AND THEN THE TRANS., IT DOES GET A LITTLE TIGHT. AS FAR AS THE CROSS MEMBER TO PAN, (MUTUALLY THE SAME) IF YOU NEED A PIC I'LL GET ONE FOR YOU !Malicruiser wrote:His is a SMALL BLOCK.2fat2fly wrote:BIG BLOCK OR SMALL BLOCK, NEED TO KNOW74Malibu383 wrote:Guys - I need help picking out an oil pan with increased capacity. Here's my problem. I need it to clear both the passenger side Hooker Super Comp header and not hang lower than the motor cross member. I would just take some measurements of the current one in the car, but it's NOT in the car right now. The motor is being torn apart as I type, and I have no way of taking measurements on it.
Kyle - Thanks for the photos. Helps a lot!
Pila - Thanks for the sump measurement. Appreciate it!
2Fat - Thanks for responding as well.
Looking at the Moroso 20205:
Moroso #710-20205
Street/Strip Oil Pan
• SBC 1986 and Later Block w/ One-Piece Rear Main Seal
• Wet Sump
• 7 Quart Capacity
• 8-1/4" Deep
• 10-1/4" Kick-out
• Steel
Going off of Pila's measurement, and Kyle's photo, I'm hoping this will work.
Thanks for all of your help!
Moroso #710-20205
• Wet Sump
• 7 Quart Capacity
• 8-1/4" Deep
• 10-1/4" Kick-out
• Steel
