73 receiver drier
2 posters
73 receiver drier
Any of you ever replace this in your 73 ? Its right next to the Radiator on the driver side. Did the one you replaced it with have a site glass? It seems many that they sell in a regular parts store wont fit in the bracket. Im getting ready to do some AC work on my car (finally) and I want to get it all together before I start.Do you still need the site glass if its converted to 134,does it matter?
Re: 73 receiver drier
Ant, I dont think the sight glass would matter at all. No one has used one for years and I've never seen one on a 134 system. If you need a hand with the conversion, let me know. I have a set of 134 gauges and a vacuum pump that works off your air compressor. I've done about 5 conversions all with good results. I also like using, if they make it for your monte, a SMART VOV. Its basically a new orifice tube that has a light spring on the needle. Definitely made a nice difference in my tahoe and my wifes old bereatta. Let me know if you need a hand.
Joe,that is very nice of you thanks ! Is the orifice tube in the expansion valve? Where can I get a smart vov? Im trying to get everything together before I start.I was going to change the evaporator too but the thing is 73 only and about 350 bucks. Im going to do a bunch of stuff (heater core and install a new carpet and a few other things) then the AC.
The smart VOV is an orifice tube. I forgot that you have an expansion valve. Wonder is there is a change over for it. WOW $350 for the evaporator. Is yours leaking? Can a radiator shop maybe work some magic on it? Let me know if you need anything.
I was thinking the same about the evap. Im not buying it,there was no indication of anything being wrong with it,I just figured that since I had it all apart I would see if I could change it. I bought the updated POV valve already that cycles the compressor like a new car now just have to buy the compressor, exp valve and drier and get it evacuated.If something goes wrong with the evaporator I will deal with it, probably get it fixed that cant cost 350 bucks.
Search around for the parts but also check rockauto.com They have lots of stuff for our cars.
Im getting the compressor from them and the expansion valve ,the drier I will get from National parts depot.
Joe,on further inspection it seems the 72 evaporator is very similar to the 73 why the guy wants so much for the 73 one, I dont know .The lines coming from the 72 style look exactly the same from the pics I can make out on ebay. Also the case on the 73 splits open so I dont have to wrestle the big damn thing out form under the hood but again im just going to replace what I said and see what happens for now.
By the way the cruise night starts on rt 52 in Carmel at Shoprite on the 21st of this month. I guess it will be our new spot for Sat nights.
That would be cool if you can make the 72 fit. I'm going to try to stop by on occasion at shop rite. I fish alot of tournaments on saturdays so I'm usually wiped out on sat. night. But I'd like to see what shows up.
