rust
bagpipe71
Re: rust
I've used it on smaller parts; i.e. brackets, shields, etc. Couldn't begin to make a claim one way or the other as to whether it's worth a crap over the long haul, however.
Re: rust
Use Por15 or Eastwoods product. Can't vouch for Rustoleum, maybe someone else can?
Re: rust
thanks ,don't think anyone can vouch for them to much, don't belive they have been out forty years yet but i hope they help.
bagpipe71- G3GM Member
Re: rust
A couple other members have posted favorable things about the Rusty Metal Primer and I've used it but I'm partial to the POR 15. If you get the scale off, you can paint right over the rusted surface and it will bond to the rust and prevent moisture from getting back to the metal. They do recommend 2 coats and the stuff is kind of expensive. I would get one of their other colors to insure even coverage. It's hard to tell otherwise if you get an even second coat. I'm using it everywhere and if I'm going to leave something black, I'll use the silver as 1st coat and vice versa. You will still need to prime over it for a topcoat and the stuff is not UV stable. I would recommend you top coat even if it's the frame or the undercarriage.
Re: rust
por15 is what i was think of ,with brush on bedliner to top coat floors with?
Re: rust
I will be doing that for the undercarriage with a self etching primer for over the por15. I am thinking of using a rubberized material for the sound deadening but have not researched which one yet. I think I've seen Dupliclor has one, Rustoleum, 3M, Herculiner...etc. We have a member hear who took his body to Rhino Liner when it was off the frame. There is a post here about, he did his front wheel wells too.
https://www.g3gm.com/t4500p60-1977-chevelle-malibu-classic-progress-photo-s-aka-mali?highlight=aka+mali
I think he has more pics in his other posts for his car too.
Re: rust
Do not put "self etching" primer over POR15! It is made for use on bare metal and contains an acid. Instead use Epoxy primer. 35 years ago I used "rust converter" on a 71 Impala I had and it worked great. It was made by a name brand company which I forget the name of. Oops, It was Extend! JB
Re: rust
JB2wheeler wrote:Do not put "self etching" primer over POR15! It is made for use on bare metal and contains an acid. Instead use Epoxy primer. 35 years ago I used "rust converter" on a 71 Impala I had and it worked great. It was made by a name brand company which I forget the name of. Oops, It was Extend! JB
Should have been more specific JB, thanks. Por15 makes a self etch that is safe to use over the Por15 paint. Or they make a "Tie coat" primer.
http://www.por15.com/SELF-ETCHING-PRIMER/productinfo/SEPG/
Re: rust
Rustoleum works well with the rusty metal primer and its cheap. Use gloss black its stronger seem to be tougher. POR 15 should always be top coated if it will be exposed to sunlight at all. It has no UV protection. Even your chassis should get some sort of top coat.
Re: rust
We use rustolium on ALOT of stuff, and no problems yet
1973chevelle- G3GM Member
Re: rust
I like the Semi-Gloss Rustoleum alot, too. Seems to lay down a nice, hard coat that holds up well. I always remove as much rust as possible by disc sanding and wire brushing first, though. Someday, I'll invest in a portable sandblaster for smaller parts.
Re: rust
I like to use the semi gloss under the hood. Its great for brackets and stuff like that.
