how to remove the front clip?
G3GM :: G3 Tech :: Body
Post by 73 Guy on Wed May 09, 2012 2:04 am
I'm working alone and was wondering if you guys could give me a removal process to take the front fenders and nose off. Can the fenders come off with the bumper still installed?
Thx
73 Guy
Re: how to remove the front clip?
Post by 77mali on Wed May 09, 2012 8:22 am
Remove your headlight housings & bumper fillers under the light housings that attach to the fenders
Mine is a 77 & the grille & attached components can be removed as one piece, 73 might be different though, not sure.
Remove hood (protect your windshield)
Remove fenders & wheel wells either together or separately (you'll have to detach the battery tray, overflow tank...etc...)
I think that's about it.
Post by micara928 on Wed May 09, 2012 1:27 pm
shouldn't we warn him if he is working alone and it is a laguna nose, the nose alone weighs a ton!!
micara928
Post by The Dude on Wed May 09, 2012 1:42 pm
Fenders are easy 5 minute job that can be done with the bumper on. Instructions per side after you remove the hood: One bolt on top by firewall, open door - one bolt near hinge, a couple more bolts up front attached to core support (take headlight buckets off with fender). All 73-77 fenders unbolt the same.
Front Laguna nose is heavy, but since you asked if it could be done with the bumper still on I am assuming you have either a Malibu or Chevelle Deluxe. Pop off the fenders & take out the radiator. Core support should only have two bolts remaining. Bumper is only attached to frame & nothing else.
If you wanted, you could have a buddy help & be able to remove the entire front clip as a unit. I have done it before & it is a little quicker but heavy. Just unbolt the rear fender bolts (top & bottom), & unbolt the core support. After everything is unplugged, it will come out as one piece. 6 bolts & 10-15 minutes including disconnecting all wiring/lines.
SOAK EVERY BOLT IN PBLASTER a day or two before attempting this job. Will make things go much easier.
Street Cred : 48
Post by 73 Guy on Wed May 09, 2012 6:24 pm
Wow thanks for the help I wasn't expecting that much info. Yea my car is. 73 Malibu. I'm just trying to clean up the firewall and engine bay so this info is excellent.
73 Guy
Post by 1973 454 MONTE on Wed May 09, 2012 7:06 pm
ive taken my whole front off in one piece. 12 bolts after the hood.
Street Cred : 35
Post by BicknellWelding on Wed May 09, 2012 8:06 pm
If you're just doing clean up. I would go with the one piece method. Its a lot less involved. If you prepped it alone, and could find someone to just help you with the pull off, you'll save time all around. Either way remember to watch for spacers between the fenders,and mark were they came from. Once you get going, The car will basically show you itself how it comes apart. Good luck
