aftermarket valve covers
Post by dhw3971 on Wed May 09, 2012 9:37 pm
Hello all:
Curious if you all can offer opinions on this: I took my '75 Chevelle wagon to the mechanic today to get a diagnosis on several items, one of which was some oil leaking from the valve covers. I had a backyard mechanic friend install some used chrome Edelbrock covers about 1.5 years ago. My (real certified) mechanic says aftermarket valve covers don't seal as well as the factory covers (which I no longer have). Has this been the case for anyone else? What methods have you used to seal chrome valve covers? Mr. Mechanic says a bead of RTV sealant on the cover followed by the gasket might work. I'd rather keep the current covers and not have to buy new ones.
Dave W
dhw3971
Re: aftermarket valve covers
Post by pila on Wed May 09, 2012 11:30 pm
For a few reasons, the chromed covers never seem to seal good. I have a set around here, that came on my Malibu, that leaked, on the original engine. Couldn't even give them away....
People have mentioned that sanding the chrome off of the gasket area helped with the leaks (?)
Post by JB2wheeler on Wed May 09, 2012 11:59 pm
I have the chrome Edelbrock valve covers and dont like the looks of them. I like the polished aluminum look more for valve covers. I have a bad leak somewhere, but have not had a chance to check it out. I have a feeling that Royal Purple Synthetic oil will get by anything. JB
Street Cred : 28
Post by Sinister on Thu May 10, 2012 1:51 am
Valve covers usually aren't the problem...it's the gaskets.
Use a quality gasket and torque them correctly,and you should be good.
They are not under high pressure..need about 10-12 ft pounds torque.
You can always use a slight more torque IF they leak,but once over torqued and the gasket is crushed,there is no going back.
Sinister
Post by ant7377 on Thu May 10, 2012 7:24 am
Tighten the bolts diagonally too not side to side. Gets them clamped more evenly.
Post by Joe73 on Thu May 10, 2012 11:00 am
I agree, torque them correctly. You can always snug them up a bit more. Also get good quality gaskets. My next time I'll be trying the ones with the built in metal sleeves to stop overtightening. They have that type for the oil pan as well.
Street Cred : 68
Post by 77mali on Thu May 10, 2012 12:40 pm
Fel-Pro....They make nice Blue colored ones that work good.
Post by Limey SE on Thu May 10, 2012 2:32 pm
also yes the chrome ones I had as well, they are never stamped right IMHO
Even with the Alum ones I put a thin bead of gasket sealant
Street Cred : 86
Post by Tom77 on Fri May 11, 2012 11:25 am
Had the chrome ones on for a while now no leaks. Good old cork gaskets dry as a bone.
