ok a question
ok a question
Post by Limey SE on Fri Mar 13, 2009 3:30 pm
i want to install this instead of using the stock blade fan what mods do i need to do, it is a puller type
Street Cred : 86
Re: ok a question
Post by BlackChevelleSS on Fri Mar 13, 2009 4:02 pm
mount it, run wires to a switch and to the fusebox.
Or correct way would be to run to a relay but its easier the other way.
Street Cred : 20
Re: ok a question
Post by Limey SE on Fri Mar 13, 2009 4:14 pm
its that easy?? gotta be kiddin me right ??
Street Cred : 86
Re: ok a question
Post by IndyG3 on Fri Mar 13, 2009 6:01 pm
It really IS that easy Cool
Just make sure you iwre it so it only runs when you turn the car on. I've seen so many cars dead cause someone added electric stuff and wired it straight to the battery and killing it...
IndyG3
Re: ok a question
Post by orange Juiced on Fri Mar 13, 2009 10:04 pm
so how do u know what type of fan to get? i have seen pushers and pullers, what the advantage of each of them? then there's the dual fan option, some of them are set for pusher or pullers or they can be mixed. then there's the CFM, how much is enough?
Re: ok a question
Post by Limey SE on Fri Mar 13, 2009 10:11 pm
my decision was based on price and that only ....ev1 else is different opinion and as far as cfm ev1's opinion varys as well it all wilL depend on what your wanting outta your motor.
Last edited by Limey aka Maligoon on Fri Mar 13, 2009 11:23 pm; edited 1 time in total
Street Cred : 86
Re: ok a question
Post by BlackChevelleSS on Fri Mar 13, 2009 11:16 pm
pullers are always better than pushers, get the most CFM your wallet allows and get the size you want, generally 2 medium sized would work great.
Street Cred : 20
Re: ok a question
Post by Limey SE on Fri Mar 13, 2009 11:31 pm
well for 40 bucks i am gonna be very happy
Street Cred : 86
Re: ok a question
Post by Hydro King on Fri Mar 13, 2009 11:33 pm
That's not bad
Hydro King
Street Cred : 4
Re: ok a question
Post by orange Juiced on Fri Mar 13, 2009 11:57 pm
Sh!t, $40 is a good price.
So lets say i run something like Limey. Since i live in Arizona, and the temp during the summer is 115+, should i go with a dual setup?
Re: ok a question
Post by Hydro King on Sat Mar 14, 2009 12:05 am
YES, Dual for arizona.
Hydro King
Street Cred : 4
Re: ok a question
Post by Limey SE on Sat Mar 14, 2009 12:29 am
yea i agree i would go with the biggest duals i could get for your heat bro
Street Cred : 86
Re: ok a question
Post by Admin on Sat Mar 14, 2009 12:33 am
the most CFM you can get through that radiator!!
Admin
Re: ok a question
Post by jonny o on Mon Mar 16, 2009 11:39 am
Careful gents... You do realize you are talking about the cooling system right?
That's like buying a condom based solely on price.
Remember, your radiator and shroud do 80% of the work. Here's the only electric fan that could keep my smallblock cool with a stock size rad.
Summit SUM-320718
It mounted easilly on the support and on the top plate with the supplied bracket and could easilly be moved as close to the rad as possible to suck good clean air.
I highly recommend running a basic toggle PRE-ignition so you can keep it running after you shut the car down. When I get done cruising for a while and know I'm going to re-fire soon I run the fan for 3-4 minutes and she cools right down. It's also great for the track, or any tuning... ever get pissed off that you have to wait to pull the plugs in between runs?
Don't mind the girlfriend or the trans/oil coolers... The large aluminum plate in the middle is the top mount for the fan. THe large elec fan is 1/2in from the rad, then the trans and oil coolers are mounted clear of the blades on the back side.
Photobucket
Photobucket
jonny o
Re: ok a question
Post by Limey SE on Mon Mar 16, 2009 2:09 pm
johny thanks for the tips and to the rest as well ..............i wont be going to the track anytime soon with this ride and if i do it will only be for a few passes if that. Just to know what it can do, not building a race car just a car i can enjoy on a daily basis and if i wanna go fast, i know that i can. THANKS FOR EVERYONES HELP ANTHONY aka LIMEY
Street Cred : 86
Re: ok a question
Post by badbiscayne66 on Mon Mar 16, 2009 11:55 pm
Very Happy
badbiscayne66
Re: ok a question
Post by Limey SE on Mon Mar 16, 2009 11:59 pm
ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
i am in heaven right now bro thanks
Street Cred : 86
Re: ok a question
Post by badbiscayne66 on Tue Mar 17, 2009 12:07 am
I thought you proly already saw these ..........Random lagunas
badbiscayne66
Re: ok a question
Post by Limey SE on Tue Mar 17, 2009 12:28 am
no not even brother keep them coming i will need all i can get for details
Street Cred : 86
Re: ok a question
Post by BlackChevelleSS on Tue Mar 17, 2009 1:07 am
man that interior colors looks gawdy. Other than that its nice.
Street Cred : 20
Re: ok a question
Post by Limey SE on Tue Mar 17, 2009 2:43 pm
mine will be black dan with bench for now till i get the matching back pattern for the back seat to match the swivels
Street Cred : 86
Re: ok a question
Post by novaderrik on Mon Apr 06, 2009 4:39 pm
you guys make this seem difficult.
here's what i did on my Monte.
i took the fan and wiring harness out of an 85 Celebrity. the harness for the fan is self contained on those cars- you get a fusible link that provides power to a relay. the relay gets power from a keyed ignition source- i used an empty "ign" slot in the fuse box. the relay is grounded thru a temp switch that screws into the intake manifold next to the thermostat housing. the stock Celeb temp switch turns on at 220 and off at 210, which is too hot. i got different switch with the same threads and wire plug at NAPA. had to look thru the book, but found one that's on at 215, off at 205. or something like that- it's been a few years since i put it in. there were some that come on as low as about 185.
the fan just bolted to the stock rad support and upper plate with the stock shroud screws in the stock shroud mounting points and drilling a couple of holes.
that setup kept it nice and cool, but i had an LT1 Caprice radiator with dual fans sitting around, so i swapped that in. it's about 2 inches wider, but it fits. for the extra fan, i added a second relay that used the same trigger wires as the other one. since the Caprice rad doesn't have a rad cap on it, i had to plumb the Caprice expansion tank into it and mount that in place of the stock overflow bottle. i tee'd into one of the heater hoses so any air would get purged thru the tank and also to allow the coolant to expand as needed.
it sounds complicated, but if you look at it, it all looks pretty stock and works perfectly. the fans only run when needed, and they aren't on when i'm going down the road.
novaderrik
Re: ok a question
Post by Limey SE on Mon Apr 06, 2009 4:46 pm
this is my first electric fan novaderrick i just didnt realize how easy it was for this setup, would have done it alot sooner if i knew how easy it is. And the fan i went with had a external temp sensor to kick the fan on at an adjustable rate from 185 to 205.
Street Cred : 86
Re: ok a question
Post by novaderrik on Mon Apr 06, 2009 8:47 pm
if you've ever wired in an amplifier, you can put in an electric fan.
novaderrik
Re: ok a question
Post by jonny o on Wed Jul 22, 2009 3:30 pm
Someone asked me for a pic of how I rigged up my Summit elec fan a while ago... Maybe Juiced?
Anyway, I dug up some old pics from when I was installing it.
You'll have to look past the oil and trans coolers....
The fan sits very close to the rad and that's the only reason I haven't needed a shroud.
Hope it helps someone.
Here is the Summit pic of the fan. I used the 90-degree brackets that came with it, just bent them back flat.
Photobucket
PhotobucketPhotobucketPhotobucket
src="http://illiweb.com/fa/pbucket.gif" border="0" alt="Photobucket">Photobucket
jonny o
Re: ok a question
