caprice rotors
caprice rotors
Post by McCauley5983 on Mon Jun 11, 2012 11:42 pm
I want to convert the front rotors to 5on5 bolt pattern are the caprice rotors a direct swap
Street Cred : 13
Re: caprice rotors
Post by thatfnthing on Tue Jun 12, 2012 9:51 am
Only if you do the spindles, bearings, and caliper brackets also: the spindle and bearings are larger than on our cars, and the rotor is one inch larger in diameter. The stock calipers are the same as ours except for a metric banjo bolt, so your current caliper should work on the new bracket if you are swapping in the run-of-the-mill Caprice equipment (i.e. not the police 9C1).
Also, the wheels will sit inboard 1/4" from where they were.
Street Cred : 55
