SWITCHING FROM SWEEP TO ROUND GAUGE CLUSTER RE-WIRE
Page 1 of 2 1, 2  Next
Post by Limey SE on Thu Jul 17, 2008 6:02 pm
1....lt green 10....blue
2....blue white stripe 11....gray
3....tan 12....lt blue
4....pink 13.....tan
5....tach lead 14....green
6....not used 15....not used
7....black 16.....pink
8....brown 17.....yellow
9....not used 18.....yellow black stripe.............................. THE REST OF THE INFO THANKS TO BRUISR................................................................ This is what I have figured out: (in no specific order other than just listing color and item it relates to). On the printed circuit there are usually 2 contacts for the bulbs, I listed whether the wire in detail is on the top or bottom of the printed circuit twist in bulb, some wires share the same path on the printed circuit.
1. Light green- hi beam (top)
2. Blue/white stripe- oil sending unit (top)
3. Tan- Emergency Brake Works when grounded out.
4. Pink- Common connection (shared by oil, brake, and Tach.
5. This is the Tach lead. (provides the signal from dizzy).
6. not used
7. Black- Common connection shared with Tachometer (middle of tach), and hi beam (bottom).
8. Brown- Amp meter (Lower)
9. not used- This is the top connection for the amp meter.
This is also the location for the volt gauge connections.
10. Blue- Right turn signal (top)
11. Gray- Common connection right turn signal (Bottom)
12. Light Blue- Left turn signal (top)
13. Tan- Fuel level indicator (top)
14. Green- Temperature gauge (top)
15. not used- This is the tailgate ajar light. (top)
16. Pink- Common connection. (Fuel,Temp. and Tailgate)
17. Yellow- Seat belt (top)
18. Yellow/ Black stripe (bottom)
If you ground out the yellow wire #17 the buzzer will sound.
As listed above, if your cluster uses an amp meter instead of a volt meter you can add your own wires to make the gauge work.
Also, If your cluster doesn't have a TACH, and you would like to add one, keep the tach in the cluster, and look at the back of it to see which studs connect to the printed circuit. Mark them, then follow the above and you can find out which 3 studs of the 6 or 7 are used to operate the tach.
Street Cred: 60
View user profile
Re: SWITCHING FROM SWEEP TO ROUND GAUGE CLUSTER RE-WIRE
Post by Hydro King on Fri Jul 18, 2008 9:24 pm
Thanks Maligoon, I will need to know whats up when time to custom build the dash.
Hydro King
2008 Donating Member
Street Cred: 4
View user profile
Post by Limey SE on Fri Jul 18, 2008 9:25 pm
FIRST HALF WAS MINE BRUISR FINISHED IT WHEN HE REDID HIS CONVERSION BUT STILL VERY HELPFULL INDEED
Street Cred: 60
View user profile
Post by Hydro King on Fri Jul 18, 2008 9:41 pm
Bruiser whats up with the dash bro.
Hydro King
Street Cred: 4
View user profile
Post by Bruisr on Tue Jul 22, 2008 2:38 pm
Alright you twisted me arm hard enough, I'll go take a few pics. BRB.
I'll try to get a pic of the blue LED lights and white face gauges when the sun goes down tonite.
Street Cred: 0
View user profile
Post by Hydro King on Tue Jul 22, 2008 8:21 pm
I love pics, post post post! Love that ride
Hydro King
Street Cred: 4
View user profile
Post by Bruisr on Wed Jul 23, 2008 3:59 pm
These are pics of the white face gauges with blue LEDs.
Street Cred: 0
View user profile
Post by Limey SE on Wed Jul 23, 2008 5:23 pm
that looks really good dan are there any more colors available or is it just blue??
Street Cred: 60
View user profile
Post by Bruisr on Thu Jul 24, 2008 4:12 pm
Colors available are Red, Blue,Green, White, and Yellow. I think thats it, but not positive. I just received my order for about $120.00 worth of LED lights for the rest of my interior and a complete set of lights for my Dad's 66 chevelle. We did the same thing to his gauges. I even got the bulbs for my monster tach, autometer gauges, and even the little shift lite on the tach. Bulbs for the monster tach are known as the 074 style bulb, they consist of a single LED.
http://info@whitegauges.net/products_list.php?catID=4550
Street Cred: 0
View user profile
Post by Hydro King on Mon Aug 04, 2008 8:37 pm
Cool thanks for the link.
Hydro King
Street Cred: 4
View user profile
Post by billy-ray on Wed Mar 18, 2009 6:35 pm
i got the sweep gauge in my car found some red light bulbs and since the gauges are black with white numbers and the red lights only light up the numbers so it looks really cool at night
billy-ray
Street Cred: 13
View user profile
Post by Hydro King on Wed Mar 18, 2009 8:57 pm
post a pic billy.
Hydro King
Street Cred: 4
View user profile
Post by BlackChevelleSS on Tue May 19, 2009 10:03 pm
this is not telling how to rewire thats just listing the wire colors and what they do. No actual sweep to round gauge rewiring going on....
Street Cred: 13
View user profile
Post by billy-ray on Thu May 21, 2009 9:58 am
ill try to take better pics later but here you go
the tach
[img][/img]
the temp gauge
[img][/img]
i tried to get pics of rest of dashboard but hard to see. the rest of the dash has red lights in it. the sweep cluster has an eerie red glow that ghosts in and out because of the street lights at night and looks really cool
billy-ray
Street Cred: 13
View user profile
Post by Limey SE on Thu May 21, 2009 1:04 pm
1....lt green 10..changes to ..blue
2....blue white stripe 11...changes to......gray
3....tan 12..changes to ..lt blue
i think you get the idea now I HOPE
Street Cred: 60
View user profile
