Intergral Windshield Antenna
This plug looks like it will disconnect from the housing...tried very lightly to remove it but it did not budge, afraid to break the wire that connects up into the glass. Anyone remove theirs?.....Prob just have to wiggle it a bit but want to be certain. Thank you.
Re: Intergral Windshield Antenna
When I had the windsheild replaced on my 73 the guy just yanked it off. Maybe spray some penetrant on it and let it sit for a little while.
ant7377- G3GM Fanatic
- Street Cred : 35
I've replaced quite a few of those types of windshields and never had a problem. That plug should come off. I think I'd try to grab it gently with pliers so you dont rip the connector out of the plug.
- Street Cred : 71
Thanks Fellas- didn't know if there was some kind of trick to it. Maybe if I screw it back in also, might get more leverage. Will use some PB Blast & my wee little pliers.
If you mess up that connector, on the coax that runs to the radio, I may have an extra coax assembly for ya. I would have to look.......
If your just removing and then replacing the same windshield, I believe you can leave the connector plugged and pull the coax through the hole.
77ElClassic- Donating Member
Since that connector plate has rust on it, the plug etc may have some corrosion on it. It would be a good idea to take it apart and check it. Easier now than when the car is back together, if the radio acts up. A bit of silicone grease, like DC4 etc in the connector, will keep the moisture out also.
I personally like the windshield antennas. No external antenna sticking up, to get broke etc.
I remember when I had the Cutlass turning on the radio by accident while going through a car wash. It was a power antenna...ouch.
I've yet to see a '73-'77 Cutlass with a power antenna setup. Matter of fact, I've not seen any GM "A" body with a mast antenna. Did they mount the antenna in the fender or rear qtr?
- Street Cred : 67
Fender passenger side front. It was a Salon model- just about every option avail....let's see, there's the power antenna....
AM/FM Casette
Cruise Control
Push button rear defrost (no vents but wires)
tilt steering
power buckets
power windows
power door locks
110 MPH speed-o
front & back map lights
there's prob more I'm forgetting, LOL.
AM/FM Casette
Cruise Control
tilt steering
power buckets
power windows
power door locks
110 MPH speed-o
I've had my share of problems with power antennas. The Buick I just bought has one that works OK. (so far)
I know a guy with a 79 Trans Am with all of 5,000 miles on it and the only the wrong is power antenna is broken. There is a guy that rebuilds them but when they tried to deal with him he was a bit of a nut.
- Street Cred : 35
» Removing scratches from Windshield
» UTV Tech Windshield Stiffener Solves a Sucking Problem
» Satelite Radio Antenna Question
» For Sale: Firestik FL3B Firefly 3ft Antenna and Quick Disconnect
» CB antenna adapter for garmin
» 73 CHEVELLE ,Austin
» New Member 1975 Laguna s-3
» New guy!
» 75 Laguna , rough...but all there ?
» The ROTW Rocks
» 75 Gmc Sprint Sp from Quebec
