Summit- Rear Sway bar
Page 1 of 2 • Share •
Found this on their Fl-E-bay store. Good price for new? I've seen others from the "famous" manufacturers going for WAY MORE.
http://www.ebay.com/itm/Summit-Racing-Sway-Bar-Gray-Steel-Rear-1-1-8-Dia-Buick-Chevy-Olds-Pontiac-Kit-/370642709900?forcev4exp=true
Re: Summit- Rear Sway bar
Paul,honestly my car does really well with a stock one you can probably get for 10 bucks used. It really sticks good for a car this size, ive got a bigger one in front though from a 75 Trans Am.
ant7377- G3GM Fanatic
- Street Cred : 35
ant7377 wrote:Paul,honestly my car does really well with a stock one you can probably get for 10 bucks used. It really sticks good for a car this size, ive got a bigger one in front though from a 75 Trans Am.
$10.00 I'd pay in a heartbeat & have no problem restoring...
I will look around and see what I find.
- Street Cred : 35
http://www.ebay.com/itm/1973-75-76-77-CUTLASS-MONTE-CARLO-REAR-SWAY-BAR-USED-/150628248013?fits=Model:Monte%20Carlo&hash=item231224a9cd&item=150628248013&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
79 bucks? No way. I will look around for you .My buddy put one on his 73 Chevelle that he got on ebay for ten bucks ! And we picked it up !
- Street Cred : 35
I know this is a little more at $124.00;
http://www.ebay.com/itm/64-77-GM-Body-Rear-Sway-Bar-Kit-1-Addco-939-New-/390421486050?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5ae6ef19e2
But it is a good price for a new 1" bar with all hardware. His store looks pretty good;
http://stores.ebay.com/Tamrazs-Parts-Discount-Warehouse?_trksid=p4340.l2563
77ElClassic- Donating Member
LOL- thanks guys....I'm thinking the 1-1/8" is the "stock" diameter for our cars- yes?
I thought it was the 7/8" n the rear. Could be wrong though.
I bought a caprice rear bar for 75 shipped. Found it on CL. I do have extra
original rears.
original rears.
- Street Cred : 35
What's the diameter of the original stock ones?
OPGI has them too....on sale for $113 (list $172)...
http://www.opgi.com/p/suspension/6371/164/ADDC324.html
I was surprised to find them "new" anywhere. Hotchkis makes nice stuff but all their stuff is very expensive. I guess you get what you pay for...hopefully.
77mali wrote:LOL- thanks guys....I'm thinking the 1-1/8" is the "stock" diameter for our cars- yes?
Nope 7/8 is stock for us Grab a Junk Yard Impala SS / Cop Car Caprice rear sway bar they are a direct fit
the NIB brackets and the sway bar from the caprice 9C1 police package from mid 90's, if you get new brackets remember to hang onto the 8 self tapping bolts you will need them for the new bracket for the side holes are not threaded and you have to run the bolts in before mounting the brackets to thread them..............
OLD SWAY BAR
NEW SWAY BAR BIG DIFFERENCE
- Street Cred : 90
That's good to know. Thanks guys! Mali didn't come w/ one so no reference point. Would the larger 1-1/8" bar be any better in terms of performance? The one area of the car that needs a total "upgrade" is the rear suspension, thinking of even spending the $$ for the adjustable lower arms & modifying the shocks/springs...etc.
Handling, performance wise, a bar especially a bigger bar is and excellent choice. For dragging and off the line, I find that my chevelle launchs nicer without the bar.
- Street Cred : 71
Thanks for the info Joe. I'm not worried about off the line but I'd like it to be able to corner & even be able to drift a bit, when necessary. I'd really like to put in a traction & sway system like with the G-body Regal GNX
but that would probably require "custom" fabrication....ugh.
LOL- just scored one for $75.00 @ a (somewhat) local U pull...picking up tomorrow, guy says he got the hardware & fasteners. We'll see.
My thanks to yet another 1973 Monte Carlo contributing to my Chevelle!
I've been thinking about a bigger bar on the front of my Elco project. I have the stock 7/8" on it right now. I have a stock rear bar, but I don't like the way it hangs down on the 9" Furd rear end. Might check what other folks are using on the Furd rear.
i'm curious Bill- why the 9" Ferd rear? I know they're a common swap but are they that much beefier than the GM 10 bolt?
The Furd 9" is much beefier than out 10 bolts. Much better if your putting out huge power. Our 8 1/2" 10 bolts have a larger pinion bearing than the 64-72 12 bolts. Having the larger pinion bearing makes ours beefier than the 1970 1/2 and prior 10 bolts.
- Street Cred : 71
I know Bill's Elkie is going to put out some big numbers. My measly 350 (well 355 now- LOL) will be putting out 350 hp but I think the 3.08 rear can handle that.
The 8 1/2" 10 bolt does real well. I've havent had any problems with my 3.42 or 4.10 rears with lots of hole shots on them. My buddies grand national runs in the 9's with his 10 bolt.
- Street Cred : 71
77mali wrote:LOL- just scored one for $75.00 @ a (somewhat) local U pull...picking up tomorrow, guy says he got the hardware & fasteners. We'll see.
If they are worth that much, i think i should sell a couple of mine.
- Street Cred : 35
In my case the car had no wheels and is sitting on the ground- had to have the yard pull it for me. I don't like this yard too much- they have a huge "retail" operation and charge a premium for parts. Still, no shipping to pay so I think I did ok. These "parts" cars are few & far between here.
Still gots all that good clean dirt on it :-)
7/8"? (close enough-LOL)
Dam I would have given you my old Bar if you would have said something yu pay ship of maybe 25 that is a stock size bar
- Street Cred : 90
» Rhino rear sway bar removal
» Rear Sway Bar Delete on RZR-S
» Rear sway bar removal-has anyone done this?
» Noise in Rzr rear
» RZR rear seat and cage.
» Noise in Rzr rear
Page 1 of 2
» Pro Street design concepts
» 700r4 trans problem?
» Where are you at picture
» 73 LeMans
» really NICE '73 Laguna- West Virginia
» 73 CHEVELLE ,Austin
