Fuel Tank Question
Fuel Tank Question
Post by Biomedtech on Sun Oct 28, 2012 7:16 pm
Since the B Bodied 89 Caprices used the same frame as our G3's i was wondering if the tanks are the same. My Holley blue pump is starting to intermittently take a Turd , and I wondered if the pickup dimensions are the same could I drop in a sender/pump from an 89 caprice and run it with that. From looking at specs on the tanks the only difference in dimensions is a 3/4" difference in tank height, length/width are exactly the same.
Since the Vortec motor in my 'Guna has no provision for a mechanical fuel pump I figured this would be the easiest way. If this seems feasible would I need to run a return from my regulator and if so can I use the old vent line for that?
Biomedtech
Re: Fuel Tank Question
Post by 1973 454 MONTE on Sun Oct 28, 2012 7:50 pm
I have a caprice tank in the barn the neck is different from what i can see. I can get size tomorrow.
Street Cred : 35
Post by davesr_7 on Mon Oct 29, 2012 7:38 am
is the c89 chevy wagon frame same as the el camino a body
davesr_7
