[b]Wheel opening moldings[/b]
bigvinnie
1973 Elcamino or Sprint wheel opening molding part numbers for front and rear with out the rocker panel molding would anyone know the part numbers ...I am getting conflicting numbers on elcamino central...can anyone clear up this issue up...so that I can make sure these parts I am gonna buy are the right parts...please help ASAP
bigvinnie- G3GM Newbie
Re: [b]Wheel opening moldings[/b]
Did you find a source for new stuff, or are you looking at used parts ??
Bill
Bill
Does it matter whether it's got rocker moldings or not? I have a 1997 OPGI catalog that only lists one style. By the way, they were still offering original GM moldings at that time...$32.95/ea for the fronts, $36.95/ea for the rears!
I found a source for new moldings...just wanna make sure they are the right ones....the ones that are used with the rocker panel molding are shorter on the leading edge side for the front and back , to accomadate the rocker molding. these are the numbers I am working with , for the back 8706531 and 8706530 and the front 6258031 and 6258032....can any one verify these numbers please...these numbers I believe to be the ones for the molding that does not accomadat the rocker panel molding
My parts catalog doesn't help much, since it shows rocker moldings on all models, in the drawings.! But the first two part numbers you list are called out for just plain "Sprint" while the Custom & Classic have different numbers. So I would think those are correct.
I have the part numbers you listed for the front. For the rear, I show 8706531 (RH) and 8706530 (LH) That for a plain Sprint.
Hope this helps..
Hope this helps..
I know this is an old post, but I was wondering if anyone ever found a source for new wheel well moldings?
bitterfitter- Donating Member
https://www.thepartsplaceinc.com no prices listed.
XP4805V (1973 - 1977 Chevelle) WHEELWELL MOLDING FRONT - LH Call
XP4806V (1973 - 1977 Chevelle) WHEELWELL MOLDING REAR - LH Call
XP5131V (1973 - 1977 Chevelle) WHEELWELL MOLDING FRONT - RH Call
XP5132V (1973 - 1977 Chevelle) WHEELWELL MOLDING REAR - RH Call
Hey thanks for posting that. I did not know they had those. I don't plan to use, mine anyway, but it is good to know for future reference.
When they say "call", it usually means they may have some from time to time...
