Pulse wiper wiring
Page 1 of 2 1, 2  Next
Pulse wiper wiring Empty Pulse wiper wiring
Post by Biomedtech on Sun Dec 30, 2012 7:07 am
Anyone know if the pulse wiper wiring is different than a standard setup? I already have both a pulse wiper motor and switch from a guna I'm stripping.
Last edited by Biomedtech on Sun Dec 30, 2012 7:08 am; edited 1 time in total (Reason for editing : Cuz I can't spell when I'm gettin my drink on!)
Biomedtech
Biomedtech
Pulse wiper wiring Empty Re: Pulse wiper wiring
Post by 1973 454 MONTE on Sun Dec 30, 2012 9:59 am
You need the extra wire harness. It has 3 wires orange white and green.plugs into the extra plug coming out the switch.
Street Cred : 35
Post by Biomedtech on Sun Dec 30, 2012 11:46 am
I'll make sure to pull that too. Thanks!
Biomedtech
Biomedtech
Post by 1973 454 MONTE on Sun Dec 30, 2012 1:36 pm
Measure the hole in the old firewall for the grommet also. Put it in the same place so the wire does not become to short.
Street Cred : 35
Post by Landonus on Sun Dec 30, 2012 7:34 pm
Is pulse same as intermitting? I pulled a bezel from a Laguna today that had a push switch to the left of the wiper switch, is that what I have?
Landonus
Landonus
Post by Biomedtech on Sun Dec 30, 2012 8:19 pm
Yup thats what it is.
Biomedtech
Biomedtech
Post by Landonus on Sun Dec 30, 2012 8:20 pm
Awesome! Too bad everything I would need for it to work is shot..
Landonus
Landonus
Post by Mcarlo77 on Sun Dec 30, 2012 9:42 pm
I've got the correct pulse wiper motor A$$'y. Only thing else you'd need is that extra wiring harness.
Street Cred : 68
Post by Landonus on Sun Dec 30, 2012 9:56 pm
I've got the harness reckon'. Dunno if it's worth the trouble though. I saw an aftermarket kit somewhere...
Landonus
Landonus
Post by texan01 on Mon Dec 31, 2012 12:04 am
I did the swap on mine, it's a worthwhile upgrade if you do drive it. Takes all of about 10 minutes really.
Of course the junkyard wipermotor I got off a 77 Fleetwood fried, pulse board seems good, but the motor itself is bad. So its back to two speed wipers for now.
texan01
Street Cred : 6
Post by Landonus on Mon Dec 31, 2012 12:19 am
texan01 wrote:I did the swap on mine, it's a worthwhile upgrade if you do drive it. Takes all of about 10 minutes really.
I drive it everywhere every day, that's how @#$% like this happens...
Pulse wiper wiring Resize17
Landonus
Landonus
Post by Landonus on Mon Dec 31, 2012 12:27 am
I spoke to someone here a while back about the subject and they went in to detail how difficult it was. Needed wires, needed the right kind of motor, crap to go in the dash. I'll take your guys word for it though. How does the intermitting wipers work? Are they diffrent settings or is it a one speed deal?
Landonus
Landonus
Post by Mcarlo77 on Mon Dec 31, 2012 12:57 am
It's not a big deal at all to upgrade to pulse wipers. Yeah, you need the pulse style motor and that extra harness, but that's it. Not sure it's a 10 minute job (would take me at least that long to replace the wiper motor), but if you set aside an hour, you'd be more than covered.
The way they work is you slide the wiper switch bar and it regulates how often the wipers cycle (doesn't just have the stops for the normal two settings). I've seen the rotary dial kind of switch in Montes.
Street Cred : 68
Post by Landonus on Mon Dec 31, 2012 2:58 am
Do I just need the harness from the button to the motor? I saw the rotary one in my owner's manual. Or so I thought. But yeah, the two regular settings... hate it.
Landonus
Landonus
Post by 1973 454 MONTE on Mon Dec 31, 2012 7:20 am
theres 2 styles. this one will fit 73-77 bezelsPulse wiper wiring Wiper210
http://www.ebay.com/itm/NOS-WINDSHIELD-WIPER-SWITCH-1977-EL-CAMINO-MONTE-CARLO-MALIBU-w-PULSE-WIPER-/300831606175?pt=Vintage_Car_Truck_Parts_Accessories&fits=Model%3AMonte+Carlo&hash=item460af6059f&vxp=mtr
because of the lever that controls the pulse,this wont fit 73-74 bezels.the hole is to small.
Pulse wiper wiring Wiper310
http://www.ebay.com/itm/NOS-WINDSHIELD-WIPER-SWITCH-75-76-EL-CAMINO-LAGUNA-MONTE-CARLO-w-PULSE-WIPER-/290831879196?fits=Model:Monte Carlo&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr&hash=item43b6ee4c1c&nma=true&si=RRdWB74iyizQcvY8kKVAp9U2NRA%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Street Cred : 35
Post by dragons_lair59 on Mon Dec 31, 2012 10:39 am
he has the bottom one
Sam
Managment
Managment
Post by texan01 on Mon Dec 31, 2012 10:56 am
I've got the round knob one, the hardest part is the snaking of the two-wire pulse harness through the hole below the washer bottle, over the brake booster mount, and to the motor.
The motor I got from the junkyard had the B/C/D body pivot that's too short for our cars. Swapped that out and bolted it back in, along with adjusting the park position a bit. So I was exaggerating a bit, but it still took me less than an hour to install it.
From what I understand of the circuit, it's basically a rheostat that operates a thermal relay (like a turn signal flasher) and the more voltage you apply, the more often it cycles, and almost all on the motor.
Now you've got me ready to order that motor for my car, since its been my DD for the last 3 weeks.
texan01
Street Cred : 6
Post by texan01 on Mon Dec 31, 2012 10:58 am
Ouch! sorry man!
texan01
Street Cred : 6
Post by thatfnthing on Mon Dec 31, 2012 11:08 am
texan01 wrote:From what I understand of the circuit, it's basically a rheostat that operates a thermal relay (like a turn signal flasher) and the more voltage you apply, the more often it cycles, and almost all on the motor.
The control is a rheostat, but there is actually a timer circuit in the w/w motor itself that reads the value of the rheostat. (I did a lot research when I was upgrading to delay wipers and a real multifunction lever like I got attached to in one of my trucks.)
Street Cred : 58
Post by bitterfitter on Sun Dec 29, 2013 1:51 pm
Do you guys have any ideas where I could locate one of the turn knob style switchs? I have the one with the slider lever but it does not fit in the hole on my '74. What if I changed the dash bezel to one from a 1975-77? Would this work?
bitterfitter
Post by thatfnthing on Sun Dec 29, 2013 2:26 pm
At least for Montes the later dash is the standard upgrade, since the delay switch is physically larger than the previous non-delay one.  I can't speak to the Chevelles, but it sounds like a similar situation.
If you have the Fisher body manual for 74 (or really any of 73-77), it will show the switch arrangements for the other GM cars -- perhaps one of those switches would work, since they were not all the same.  Otherwise, I think you're looking at dash surgery.
Street Cred : 58
Post by bitterfitter on Sun Dec 29, 2013 3:01 pm
Is this one you are selling or did you just happen upon the auction?
bitterfitter
Post by 1973montec on Sun Dec 29, 2013 11:11 pm
been watching the auction not mine. chris has one just like it in his 73 monte.
Post by texan01 on Sun Dec 29, 2013 11:17 pm
I have the one that has the turn knob, and I pulled it from a 77 Monte, and installed it on my 77 Malibu, no fuss, no muss, it bolted in like it belonged there. I did install the knob from a Pontiac GP because the Monte knob was missing, but since its chrome and looks almost like the headlight knob and the radio knobs I like it.
Those switches are virtually made of unobtainium.
texan01
Street Cred : 6
