Lifting rear end
+7
LSANTI76
alleyball4
11 posters
Lifting rear end
Whats the easiest way to lift the rear of a 77 malibu to give it more rake? This might be a dumb question but I'm new to this so any advice would be greatly appreciated!
mychev123- G3GM Member
Re: Lifting rear end
The cheapest way is probably some air shocks. I did that in my 76 Monte when I was younger, but after a while it was kind of goofy, especially since I didnt have big fat tires and wheels to fill up the wells, lol.
JiMi_DRiX- G3GM Enthusiast
About 60-70 bucks for new rear springs. Simple install. Otherwise maybe some springs from the bone yard.
keep in mind, raising the rear end affects the handling ..
I raised mine, and have the big fat tires.
Let the experts on here, discuss that with you, because I don't know what you should and shouldn't do.
We have the rear sway bar ... but I know back in the 70's, we all threw traction bars on the back end, when we raised it in the air, whether it needed it or not ... lol
alleyball4- Donating Member
Get some springs from a 75 Caprice or other full size GM car pre 77. It will ride a little rough though.
I currently have springs from a 74 olds 98. This lifted it probably 2 to 3 inches above stock. The ride in the rear is very stiff especially over speed bumps. I put them in in 1995 and its still jacked up (and still rides like crap). Just fyi in case you go that route.
back in 2002 i put bigger springs, still sits the same this day 10 years later.
I FOUND THE #'S THAT I USED.WHEN I DID
THE SUSPENSION ON MY
74 WITH A 350, back in 1990
I USED NAPA SPRINGS.FOR THE FRONT I USED 277-1954 AND
THE REAR 277-3189.
THE REAR 277-3189.
Great information has been given here. I guess it all depends how much you are intending to raise the rear. Based on my past younger experience with my '76.. I had ran air shocks to level out the rear when boat towing. Sometimes I would use these air shocks to raise the rear to have that 70's rake hot rod look when not towing. Poor ride quality & handling was noticed when raising the rear anywhere from 1-2 inches higher than factory front ride height. If you do raise the rear, I would do some coil spring research & use springs to achieve your goal. You could also use your existing springs & use those coil spring spacers that install fairly easy depending on which thickness of spacer. These spacers are the ones placed on top or bottom of your spring during install(not the ones sold that are sandwiched in the middle of spring). Spacers would be the least expensive option sold for raising your rear from 3/4" - 2 1/2". At least with springs you let the suspension have travel vs air shocks somewhat limiting suspension travel.
On a side note...just an opinion. Depending on wheels.. for the most part I like 73-77 Chevelle/Malibu/Lagunas, Pontiacs & Oldsmobils at factory height or lowered with a slight rake. 73-77 Monte Carlos have an advantage of looking excellent either way of slightly lowered, stock height or raised on all four corners as 454 MONTE seems to be.
LSANTI76- G3GM Member
If you watch my thread I posted https://www.g3gm.com/t6365-qucik-video you can see the stance from several angles. My chevelle springs are 73 big block, heavy duty, with a/c springs in the front. I have rear springs that are 2 inches taller than stock in the rear. The car does not have a/c, a big block or auto trans in it. The rear has no noticeable "squat" upon launch and the front comes up about 2 inches. I'm running Competition Engineering drag shocks all around. Fronts set to 80/20 bias and the rears set at 50/50 bias.
BTW, 1973 454Monte I love that stance you have!!!
One thing to watch also when raising the rear is the added stress put on the front end. Make sure your in good shape up front or you could be asking for some trouble from the shifting of the weight.
Tom77- Donating Member
I think the reason the car rides so bad lifted is because the shocks are fully extended and cant compress due to the added height and stiffness of the springs. THey make shock extenders and ive seen them on ebay. THat I think would help the ride.
Thanx
ant7377 wrote:I think the reason the car rides so bad lifted is because the shocks are fully extended and cant compress due to the added height and stiffness of the springs. THey make shock extenders and ive seen them on ebay. THat I think would help the ride.
I agree!! Shock extenders would definitely help. The bring the shock closer to where they are supposed to operate, in the middle of its range. Then the shock can travel in and out and do its job.
I'm no suspension expert...but depending on how high you want it to look in the rear- why not lower the front slightly? That way the arse end should handle like stock. Spacers should work good too as mentioned.
Edit:
Sorry...you asked for the easiest way (definitely the spacers). The front end is much harder to remove springs than the rear. I've seen the spacers referenced on ebay & maybe 1 or 2 other sites like Jegs or Summitt. Global West makes these but there are similar ones.
http://www.globalwest.net/1621.html
Edit:
Wow thanks for all the input..I think Ill go with the spacers it seems like the simplest way .
You could have done both raised it an inch and a half in the rear and droped in the front a half an inch to a inch to rake it with out changing the handaling much
bigred84- G3GM Newbie
