power window and /or power lock switches ?'s
Post by Bruisr on Tue Feb 05, 2013 2:48 pm
I have some old power window and door lock switches, does anybody know which stud on the back of the switches does what? I'm looking to reuse the switches to keep the appearence, but since I don't have anything else to go with them, I want to see if I can use them to operate other devices. The door lock switch has 3 studs on the back, 1 of them is isolated from the other 2. Can I asuume the single 1 is power in and the other 2 control the action. What about a ground wire?
Re: power window and /or power lock switches ?'s
Post by Mcarlo77 on Tue Feb 05, 2013 4:21 pm
Not sure what you are describing with the switch pins. My factory Lock switches have three pins in a dogleg configuration; pretty much equally spaced. Can't say any one pin is isolated. I do think you have the right idea in that one is power and the other two dictate the direction of the action. If you'd like, I can get back to you with the correct color wires and which pin they go on if you can then find a schematic to confirm. I've got a harness laying around.
As for Ground...there is no wire as it is achieved through the door metal via the mtg bolts of window motor and/or lock actuator.
Street Cred : 67
Post by Biomedtech on Tue Feb 05, 2013 9:06 pm
Hopefully this will help...
Biomedtech
Biomedtech
