Polyeurethane VS Rubber
Let's have a bushing/mount fight!
Thought this would make for good reference. Let's hear from anyone who has bought, installed, and driven on these two different materials. From complete kits to small kits and single installations. List your pros and cons so folks can make an educated purchase without any unwanted surprises. I plan on replacing all the bushings/mounts on my G3 this summer and I figure this would help me as well as other people wanting to do the same, whether to decide on a full kit or to mix and match accordingly. Please feel free to post pics and or links to other threads to help combine all matters on the subject. I see posts here and there about one type or the other but nothing covering both and in any great depth, so I figured this wouldn't hurt.
Landonus- Donating Member
Re: Polyeurethane VS Rubber
I have driven on both .... but it is difficult to compare .... because there are different grades of polyeurethane. The high-end stuff is a little softer, yet has the durable features you're looking for. Spohn used to carry some of those bushings ...
http://www.spohn.net/shop/1973-1977-GM-A-Body/Suspension/Polyurethane-Bushings-Accessories/
.... they can get pricey.
Some of the stuff you see in Summit and Jegs, is a little stiffer and made strictly for the performance side. It can be a little rougher on the ride.
A good rule of thumb is, if youre planning on keeping your car less than 10 years, and not running alot of horsepower (i.e. torque) rubber should do just fine, plus it's a little cheaper, and a little more forgiving on the ride.
If your car is your lifelong playmate, or you've got a beast of a set-up, then don't cut corners on bushings, and get a high-end polyeurethane set.
I know when I see those high-end red Spohn bushings on a car .... for me, it sends a message that, "this guy didn't cut corners on his suspension".
alleyball4- Donating Member
I've been running polyurethane bushings in my front and rear control arms since the late 80's. I find they make the suspension feel "tighter" if thats the word to use. I like them for that purpose. I'm in the process of a chassis swap right now and have decided to go with rubber. I think poly would be fine but I would like something that is a little forgiving.
Just FYI, if I remember correctly, on a 73 only, there are (2) different sizes of bushing for the FRONT LOWER control arms. Dont remember the diameters off hand but you have to measure yours before you buy. 73 only!!! Just FYI.
I agree on using the poly stuff on suspension items, but I use the rubber body mounts, which have a bit of give to them for the body to sit good on the frame.
