ls1 swap in my sons 75
Page 1 of 4 1, 2, 3, 4  Next
ls1 swap in my sons 75 Empty ls1 swap in my sons 75
Post by michiganlarry on Tue Feb 26, 2013 2:56 pm
Here are some pics of the ls1 swap I am doing on my sons car.
Old drive train coming out.
ls1 swap in my sons 75 IMAG0768021813_zps596beb72
ls1 swap in my sons 75 IMAG0770021813_zps7c41e40d
ls1 swap in my sons 75 IMAG0771021813_zpse09b4570
ls1 swap in my sons 75 IMAG0774021813_zps1012bb9d
ls1 swap in my sons 75 IMAG0778021813_zpsb9c41be7
Ready for this
ls1 swap in my sons 75 IMAG0784sm_zps26ede39d
new quick ratio gear box
ls1 swap in my sons 75 IMAG0791sm_zps0707becb
michiganlarry
michiganlarry
ls1 swap in my sons 75 Empty Re: ls1 swap in my sons 75
Post by Mcarlo77 on Tue Feb 26, 2013 3:06 pm
Looks pretty much like the LS1 I saw Wallyup installing in his '74 Laguna! You two should compare notes. Wally's done an amazing job so far getting everything lined up, hooked up and plumbed. Nice job...both of you!
Street Cred : 68
Post by G3NUT on Tue Feb 26, 2013 3:10 pm
I bought the same steering box for my car.
Looks like your making progress.
G3NUT
G3NUT
Post by 77mali on Tue Feb 26, 2013 4:21 pm
Looking good.
Post by michiganlarry on Tue Feb 26, 2013 4:30 pm
Thanks. Got the fuel system sorted out thanks to G3NUT. Having the tank picked up today. No fill tube with the tank so found one at the autopartshop.com for $85. Still gotta find the rubber connector from tube to tank. Ordered the new sending unit/fuel pump. Waiting on the conversion trans extension so the mechanical speedo will work. Hopefully this weeken the engine will be in.
Anyone have an extra tach for the 2 round bezel dash?
michiganlarry
michiganlarry
Post by michiganlarry on Tue Feb 26, 2013 4:32 pm
BTW that's my 68 Firebird under the car cover in the back.
ls1 swap in my sons 75 IMAG0188sm
michiganlarry
michiganlarry
Post by pila on Tue Feb 26, 2013 4:49 pm
Nice project on the '75 ! Your son is a lucky young man ! Very Happy
Where in Michigan are you Larry ??
Bill
Post by 1973 454 MONTE on Tue Feb 26, 2013 5:01 pm
G3NUT wrote:I bought the same steering box for my car.
and what kind and where did you guys get it?
does it use our hoses,or do you need other kind?
ls1 swap in my sons 75 Icon_t16scratch
Street Cred : 35
Post by 1973 454 MONTE on Tue Feb 26, 2013 5:16 pm
my buddies wife has a 69 firebird,awsome cars.ls1 swap in my sons 75 Karin10
and he is putting a LSX 454 in his 70 chevelle
ls1 swap in my sons 75 Lsx110
ls1 swap in my sons 75 Andre10
Its going to be at Detroit Autorama. second row 20x20 spot
as of last weekend,almost ready
ls1 swap in my sons 75 Andre110
Street Cred : 35
Post by michiganlarry on Tue Feb 26, 2013 5:21 pm
This particular box has the metric o ring style connectors that the ls1 ps pump uses. I found one that I put on the firebird that uses the older style connectors. I get mine from Autozone. $130 plus $15 core.
michiganlarry
michiganlarry
Post by Wallyuph on Tue Feb 26, 2013 10:20 pm
Just found out today that my Fuel tank (from the 95 impala) that was in the car when I bought had 17 gallon of old rotten gas in it. (man does that stuff smell rotten). The sending unit is all shot and rusted up. The good thing is its a totally plastic fuel tank. Called some Tank shops and both said to put some De-greaser in it with hot water and let it sit for a few hours then, power wash it at a do it your self car wash. I have one of those car washed 2 blocks away from me. Ordered new sending unit and fuel pump today.
I like those LS 's from that cars verses the truck set up I'm running. Just hard to find a good price on them in my neck of the woods.
Car looks great.
Post by WyldeBill66 on Tue Feb 26, 2013 11:42 pm
I knowthat the LS motor makes a heck of a lot of power, but I'd have a hard time putting that ugly motor in my pretty car. I guess I'm just an old school type of guy...
WyldeBill66
Post by carcass on Wed Feb 27, 2013 12:07 am
Thanks for the thread! Please keep the pictures coming, I'd like to see the headers and motor mounts you use. Nothing like individual coils, six bolt mains, fuel injection, 60's era compression on todays pump gas all in a lighter package to make a guy feel good!
carcass
carcass
Post by 77mali on Wed Feb 27, 2013 12:10 am
I like the old blocks too (1988 & back) but when you have a car that's had suspension mods, new school rims & other serious enhancements for a "pro touring or street machine" look those LS motors not only look better in the car (more modern look) but they'll make all those other mods worth while. I think G3nut has a 6 speed trans- you couldn't run his trans on an old school SBC or BBC and have it work as good as with the LS. My $0.02
BTW- you are a nice Dad for doing this. Gotta teach them young ones right. I hope mine is done by the time my 7 YO can drive. He's got dibbs on the car. Very Happy
Post by michiganlarry on Wed Feb 27, 2013 9:17 am
Here is last nights work. I installed the mechanical speedo conversion tail shaft on the 4l60e.
old piece
ls1 swap in my sons 75 IMAG0804sm_zps594bd9f9
Old shaft removed you have to get the old reluctor off the shaft. I did not have a puller long enough so I cut almost through with a die grinder and put a chisel in the slot and gave it a smack. It cracked and slid right off.
ls1 swap in my sons 75 IMAG0806sm_zps49fc15ec
next step was to install an adaptor plate.
ls1 swap in my sons 75 IMAG0808sm_zps0d0765b1
Then slide the new reluctor/drive gear piece on the shaft.
ls1 swap in my sons 75 IMAG0807sm_zpsf01a6898
Next you line up the drive gear in the mechanical speedo hole in the tail shaft.
ls1 swap in my sons 75 IMAG0810sm_zpsa61cfc4fThen carefully remove the tail shaft and tighten 3 allen set screws to hold it in place. Next you reinstall the new tail shaft. Thighten the bolts and your done.
ls1 swap in my sons 75 IMAG0805sm_zpsee225cb1
michiganlarry
michiganlarry
Post by michiganlarry on Wed Feb 27, 2013 9:23 am
I agree that the ls will never have the eye appeal that my 428 in the firebird has
ls1 swap in my sons 75 0502001251-sm
But you have to keep up with the times and you can't argue with the cheap power the ls motors make. I have 3 times the $ in the pontiac drivetran that i will in the ls swap.
michiganlarry
michiganlarry
Post by michiganlarry on Wed Feb 27, 2013 9:51 am
Here are the dirty dingo sliders installed on the ls. 2.5 inches of adjustment. Then you just use your sbc engine side mounts. Pretty slick
ls1 swap in my sons 75 IMAG0794sm_zps958c7c12
michiganlarry
michiganlarry
Post by Wallyuph on Wed Feb 27, 2013 10:40 am
Did you swap out your oil pan?
I got my mounts from them and they have tabs welded to them as I wanted to keep the A/C and said they would fit. Still had to space them with a few washers. Was a real treat to get the main bolt through. I swapped my pan from a cast one from summit and it hit cross member even with the tabs on the brackets. That's why we had to put spacers in. With mounts all the way forward so engine is back as far as plates allow it still sits forward in compartment. Tail shaft on trany just clears rear tunnel so it did work.
The brackets you have look like you can get more adjustment but you may need to space the motor mount on frame up then in order to get pan clearance.
Here is a shot of my brackets from dirty dingo and new oil pan. sorry its the only one I have a good shot of.
[url=[url=https://servimg.com/view/17248508/154]ls1 swap in my sons 75 Img_6617
Post by michiganlarry on Wed Feb 27, 2013 11:16 am
I have the stock f body aluminum pan on the engine. It's supposed to fit but that remains to be seen. These particular mounts raise the engine 1/2 inch so that should help with the pan clearance. I would like to keep the factory ac and alternator mounts also if they will clear. I did find that my alternator bracket is cracked so I have to deal with that.
michiganlarry
michiganlarry
Post by Wallyuph on Wed Feb 27, 2013 11:26 am
with the truck intake its sits pretty high. You will not have that issue with a car intake. I did not want to spend a ton on this so I'm going with what came on it to save some cash. In my area the car engine was over twice as much as the trucks.
I bought a set of what I was told were F body manifolds (Ebay) but they did not clear they hit the frame so I ended up going with new cast iron Hooker headers.
The car I bought had a LT1 with a 4L60e trany in it at one time. The guy I got it from sold it and set a 396 in the hole. The new drive shaft that came with the car bolted right up. Just had to move rear cross member about a inch.
Its fun making it all fit, that's the love of all of this.
Post by michiganlarry on Wed Feb 27, 2013 11:33 am
I agree. Figuring it all out is what I love about this hobby too. This is my first try at the whole fuel injection thing but I am sure that once I figure it out I will never install an old school v-8 in a car again UNLESS it's a numbers matching original car. I am already thinking that my next is going to be a c4 vette rag top with an ls engine.
michiganlarry
michiganlarry
Post by Wallyuph on Wed Feb 27, 2013 12:21 pm
I agree totally, I'm keep my eyes open for a car set up not a truck one so if this goes the way I think it will. I'll be doing it to my 56 chevy with some nice upgrades. Then maybe my 73 also.
I'm more of a custom guy that a stock one. I like both but like the fun of some thing different.
Keep notes for your next one and it will go a lot easier and faster.
Post by Brainstain on Wed Feb 27, 2013 2:30 pm
I like those mounts a lot more than the ones Wally and I have. I thought the F-body pan would hit the crossmember so I have 3 different pans. My H3 pan (which is GM's "swap pan") thats going in my Vega is about 1-1/4" shorter vertically than a truck pan. I may try that in my wagon since the pan sits way too low for me.
Brainstain
Post by carcass on Wed Feb 27, 2013 9:56 pm
I love the look of the newer Chev motors just as much as the old, just in a different way, I fully think Chevrolet has perfected the small block design with the LS series, furd had the flathead in the 30's and 40's but with Chevy coming out with the first smallblock all others have paled in comparison. Whats not to like visually about a great fuel injection manifold and exposed cross bolt mains? And coils for every hole? Come on, thats just awesome right there! We've been dinkin around with HEI for long enough. Theres no way I'd hide those coils, I'd leave em in plain view and brag about the tremendous spark capability. Has anybody actually studied what a gen 1 coil goes through even at idle? let alone at 6000? Its amazing that a single coil can even jump the gap it can. Its just to much work for one coil.
Keep up the good work guys.
P.s. Do you think when the flathead V8 came out the diehard fourbanger guys scoffed at it? Or when the stovebolt six was replaced by the smallblock? Hot rods have ALWAYS been about putting the latest and greatest in our favourite cars. I appreciate traditional but converse all stars are uncomfortable as all heck.
carcass
carcass
Post by Brainstain on Wed Feb 27, 2013 10:16 pm
I want to put my coils on the inner fenders. I saw it done on an Australian car and it looked awesome.
Brainstain
