ls1 swap in my sons 75
Page 3 of 4 Previous  1, 2, 3, 4  Next
ls1 swap in my sons 75 - Page 3 Empty Re: ls1 swap in my sons 75
Post by michiganlarry on Mon Mar 25, 2013 12:49 pm
Progress is slow right now. Seems like I can't spend any quality time in the garage. Over the weekend the front clip went back on
ls1 swap in my sons 75 - Page 3 IMAG0887_zps130eac6f
And I got the Holley brackets on and most of the accessories rehung.
ls1 swap in my sons 75 - Page 3 IMAG0891_zps2d861602
Sold my CJ-7 on Sunday so didn't get anything done on the Chevelle.
michiganlarry
michiganlarry
Post by Wallyuph on Mon Mar 25, 2013 4:10 pm
Looks like hood will clear fine. A/c is close to inner fender from this photo angle.
Won't be long tell its running now.
Post by michiganlarry on Tue Mar 26, 2013 7:13 am
No clearance issues on the hood. The ac compressor actually has a almost two inches. Bad picture angle.
Left to address:
finish up fuel system
get cooling system installed
figure out what I am going to do for gauges
inside passenger compartment wiring
michiganlarry
michiganlarry
Post by michiganlarry on Thu Mar 28, 2013 11:14 am
Got out to the garage again last night for a couple hours. Got the rest of the front accessory drive installed and wrapped up along with the power steering plumbing. Got the belt right on the first try! Slow but sure wins the race.
ls1 swap in my sons 75 - Page 3 IMAG0918_zpsd82dc83b
ls1 swap in my sons 75 - Page 3 IMAG0917_zps95621152
michiganlarry
michiganlarry
Post by Wallyuph on Thu Mar 28, 2013 11:18 am
Sweet
Post by michiganlarry on Thu Mar 28, 2013 11:36 am
Thanks.
michiganlarry
michiganlarry
Post by 77mali on Fri Mar 29, 2013 4:33 pm
Nice job. Curious- what are those lines feeding by the harmonic balancer?
Post by michiganlarry on Fri Mar 29, 2013 7:04 pm
Those are the trans cooler lines. I will replace those with some straight ones once the radiator and trans cooler are mounted.
michiganlarry
michiganlarry
Post by michiganlarry on Mon Apr 01, 2013 7:36 am
It's running!. Woohoo.
Made the first attempt yesterday and it popped and sputtered then started but was running horribly, popping and sputtering. I shut it down and started rubbing my chin. My scanner showed no major issues so time for a little investigation. The passenger side exhaust manifold was warm to the touch but the entire drivers side was cold. Hmmmmm. When it was running it sounded like a sbc that was 180 degrees off on the timing. I took a shot and flipped the coil harness on the drivers side and turned the key. It started right up and after clearing the extra fuel it settled right down. I do have an pretty good oil leak from the timing cover seal around the crank so tonight I will be changing that out. Need to figure out how to post videos.
michiganlarry
michiganlarry
Post by Wallyuph on Mon Apr 01, 2013 8:53 am
congratulations that is such a great feeling when you here them start and run for the first time. Even more so with all this new wiring and ECM's boxes now days.
I got lucky with mine for no leaks yet. Its been sitting for almost 3 weeks while I work on the kitchen remodel and my daughters Boyfriend came over this weekend and was helping me unload some flooring into the shop. He asked if he could here it run. Turned the key and it popped right off. My daughter said to him when we came in "was that your reward for helping dad you get the here that car run"? He said with a smile "yep is was". I think he's a keeper I told her. He has a 98 camro with a 5.7 in it. I think he fits right in if you ask me.
Post by michiganlarry on Mon Apr 01, 2013 9:15 am
Thanks. Yea that moment is pretty intense. The first try when it popped and sputtered there were some colorfull words flying and a sick feeling in my stomach. When it finally fired I was all smiles.
Is it better to upload videos to photobucket or utube?
michiganlarry
michiganlarry
Post by thatfnthing on Mon Apr 01, 2013 9:35 am
Yep, nothing like the satisfaction at that moment when everything you did was proved right! Very Happy
Nice job on that project, BTW!
Street Cred : 58
Post by Wallyuph on Mon Apr 01, 2013 9:40 am
I used You tube
Post by michiganlarry on Mon Apr 01, 2013 9:59 am
Video link:
https://youtu.be/RX67OZ7wsHw
You can hear the exhaust is still rattling under the car when I walk to the back.
michiganlarry
michiganlarry
Post by Wallyuph on Mon Apr 01, 2013 11:06 am
Love it good job
Post by michiganlarry on Mon Apr 01, 2013 11:11 am
Thanks man. I really appreciate it.
michiganlarry
michiganlarry
Post by 1973 454 MONTE on Sat Apr 06, 2013 9:57 am
sounds good.
you did that quik
Street Cred : 35
Post by Biomedtech on Sat Apr 06, 2013 1:18 pm
NICE! See you at the cruises around the D this summer!
Biomedtech
Biomedtech
Post by G3NUT on Sat Apr 06, 2013 8:56 pm
engine sounds and looks good. did you take it for a ride yet?
G3NUT
G3NUT
Post by michiganlarry on Mon Apr 08, 2013 7:25 am
Thanks for the compliments. I am happy that it seems to be running well. I need to have this wrapped up by the end of April so I can get it shipped to my son in San Diego so not likely you will see it this summer. Got the new tires and Detroit Speed lowering springs on over the weekend. Have not driven it yet because there is no front seats or console/shifter in it yet. Also looking to sink the bumpers. Is the best bet to drill the bumper shocks? Do you weld them in place once the oil is out?
New next to old front coils
ls1 swap in my sons 75 - Page 3 IMAG0927_zps90e3afaa
New shoes
ls1 swap in my sons 75 - Page 3 IMAG0926_zps61e3aa5d
ls1 swap in my sons 75 - Page 3 IMAG0925_zpse69dba23
On the car
ls1 swap in my sons 75 - Page 3 IMAG0929_zps92658d89
ls1 swap in my sons 75 - Page 3 IMAG0933_zpsf9243f95
ls1 swap in my sons 75 - Page 3 IMAG0928_zps4fa2e05f
ls1 swap in my sons 75 - Page 3 IMAG0930_zps4983528e
michiganlarry
michiganlarry
Post by Bruisr on Mon Apr 08, 2013 10:29 am
Welding the front bumper shocks?!? Its your choice really, I did on my 74 chevelle and didn't on my sons 76 elco. However the bumper shocks can be accidently pulled out. (Not completely) My son tried to pull something with the bumper and it pulled out to its original length. He had to remove it to get it to compress back to where we had it. I'd recommend completely install everything on and around bumper so you can "tweak" the sink in distance as you like, then a simple tack weld should suffice.
Post by michiganlarry on Mon Apr 08, 2013 11:08 am
Thanks Bruiser. Did you drill two holes in the shock or will all the oil drain out with one?
michiganlarry
michiganlarry
Post by Wallyuph on Mon Apr 08, 2013 11:16 am
I welded mine up and never thought the oil in it. Just compressed them in a press and welded it.
Post by Limey SE on Mon Apr 08, 2013 11:33 am
michiganlarry wrote:Thanks Bruiser. Did you drill two holes in the shock or will all the oil drain out with one?
one hole on each end of shock is what I did with mine on the cutlass when I sunk mine in
Street Cred : 92
Post by michiganlarry on Mon Apr 08, 2013 11:44 am
Thanks guys.
michiganlarry
michiganlarry
