Rear ends
Rear ends Empty Rear ends
Post by Darkcalling1 on Wed Mar 20, 2013 11:00 am
I know it is probably on here somewhere but I can't locate it. Can someone or does someone have a list of rear diffs with disc brakes that area a straight bolt in with same bolt pattern? Thanks guys
Darkcalling1
Rear ends Empty Re: Rear ends
Post by dragons_lair59 on Wed Mar 20, 2013 1:28 pm
most dont but did find this here in the interchange area
for the disc brakes, the LS1 (98-02) Camaro and Trans Am parts will bolt right on, but later S truck stuff will probably be easier to find. if you get the 4X4 S Blazer disc setup, you will need an LS1 F body or 2wd S truck rotor to make it work since the 4X4 Blazers had a rotor with a deeper offset in it due to the axleshafts they used in the 4X4 trucks.
94-96 Caprice/Impala disc brakes bolt up, but you will either need to drill the rotors for the smaller wheel bolt pattern or get different rotors- i think the LS1 F body or S truck rotors will also work here..
you could get an impala rear and see what a local shop would charge to redrill the axles and rotors
Sam
Managment
Managment
Post by Darkcalling1 on Wed Mar 20, 2013 3:58 pm
Thanks Sam will be scouring the wreckers once weather is better.
Darkcalling1
