looks like it's stock ?
Re: looks like it's stock ?
Looks awesome!
That thing running yet? We want to see a video- put your son to work on that next time he's over helping you.
I ran it last fall, for the cam break-in, @ 2200 RPM for around 35 minutes. Came out OK, and indicated 185 degrees temp, with a 180 thermostat. Fuel pressure was 4 PSI on the engine pump, and went to 7 PSI with the electric on. I'll need to set the electric down to about 6 PSI .
I cut the oil filter apart to inspect it after break-in, and found no metal etc in the element.
Selected the trans through all the gears etc to get oil circulated etc in there & check for leaks etc.
It has only exhaust pipes back to the cross-member on it, so it's REALLY loud !
