Opera Windows 1974 Chevelle
Page 1 of 2 1, 2  Next
Opera Windows 1974 Chevelle Empty Opera Windows 1974 Chevelle
Post by v8power on Sun Mar 24, 2013 12:26 pm
Hi
I look to my opera windows on my 74 chevelle and i found under the trim a triangle window Glass but i have the small opera windows.
But it look likes Original. Is that sure?
Its possible to open my small opera window to the triangle window?
Its only a possibility question. Smile
Opera Windows 1974 Chevelle Opera-11
v8power
v8power
Opera Windows 1974 Chevelle Empty Re: Opera Windows 1974 Chevelle
Post by 77mali on Sun Mar 24, 2013 1:04 pm
Yes it is possible- there are several posts on here on the subject but if it's a factory conversion, I believe there should be a metal panel underneath the padding in your photo on the last half of the quarter window. You'd have to remove the sail panel, belt re-tractor trim & coat hook to see for sure. I wouldn't bother if it were me- It looks very nice anyway.
Post by pila on Sun Mar 24, 2013 1:58 pm
There is a triangular metal plate/skin welded across the big glass, to form the small window frame.
Your interior looks excellent by the way.
The cheaper versions used the big window, like a standard Chevelle, while the deluxe version was the Malibu, with the small windows.
But...some models of the Laguna had the big rear windows.
Look at the brochure pictures in 77mail's post, which shows a bunch of models with both styles of widows.
Opera Windows 1974 Chevelle Empty Re: Opera Window 1974 Chevelle
Post by Mcarlo77 on Sun Mar 24, 2013 2:53 pm
Mali and Pila are correct. Here are a couple pics of another '74 to confirm what you've got there. You can see the outline of the factory patch on the exterior from the cracks in the bondo.
Opera Windows 1974 Chevelle 74mali11
Opera Windows 1974 Chevelle 74mali10
Street Cred : 68
Post by carcass on Sun Mar 24, 2013 4:39 pm
woah!
my car has the small windows and I like em' its a 74 now I'm worried it has a big window hiding under a bandaid, weird!!!
carcass
carcass
Post by Joe73 on Sun Mar 24, 2013 5:22 pm
They came both ways 74 on depending on whether it was a chevelle or a malibu. Like mentioned above.
Street Cred : 73
Post by carcass on Sun Mar 24, 2013 5:45 pm
mine is a malibu classic originally a six cylinder car. what do you think?
carcass
carcass
Post by dynchel on Sun Mar 24, 2013 6:28 pm
I think the small windows were more or less standard on a Malibu classic. My '74 is a base chevelle with the large windows (original 350 2bbl). As to weather the big windows are hiding or not try pulling the interior sail panel to look. Or maybe check around the perimeter with a magnet to see if there's bondo.
Post by Mcarlo77 on Sun Mar 24, 2013 6:52 pm
That red '74 I took the pics of was a 6-cylinder car.
Street Cred : 68
Opera Windows 1974 Chevelle Empty Opera windows
Post by sick73chevelle on Sun Mar 24, 2013 7:18 pm
carcass wrote:mine is a malibu classic originally a six cylinder car. what do you think?
Did all cars with the factory patch panels have vinyl roofs covering them? I can't tell if carcass's car has one or not. Has anyone ever seen one without? I am converting my 73 Chevelle to small windows. I cut the factory panels out of a buick regal/century (I forget which, who knows the diff). These panels were just spot welded in, and the buhog had a vinyl top. I am welding them all the way around to make sure I do not get any mud crackage since I am not putting a vinyl back on it. The filler that I ground off these things from the donor car was not like bondo, more like a rubbery filler. It tasted terrible too! Probably some kind of asbestos alloy. Cough cough!!!
sick73chevelle
sick73chevelle
Post by 77mali on Sun Mar 24, 2013 7:50 pm
Hey sick73- I hope you were kidding but just in case, get a cartridge type respirator & don't breathe in any of that crap. They used a boat load of chemicals in these cars back then that would probably cost them the company by today's standards.
Post by Limey SE on Sun Mar 24, 2013 8:17 pm
Yea you def wanna wear a mask for that Sick73chevelle there prob asbestos in that old filler and this is how the 74 Small windows were done due to the GM Labor strikes back in the day they did a lot of shortcuts to keep up with production needs
Opera Windows 1974 Chevelle Capson2005
Opera Windows 1974 Chevelle Capson2001
Street Cred : 92
Post by Limey SE on Sun Mar 24, 2013 8:19 pm
They used the big triangle for the Sail panels, Then they used the material like for the rear package tray and and then cover it with upholstery to match the interior
Opera Windows 1974 Chevelle Capson2003
Street Cred : 92
Post by sick73chevelle on Sun Mar 24, 2013 8:30 pm
I appreciate all your concern for my health. I always say that I am gonna finish this car even if it kills me! But has anyone seen one with factory fillers and NO vinyl roof? P.S. You might see me in a commercial 10 years from now saying: "My name is Jim, and I got mesothelioma from my 73 Chevelle".
sick73chevelle
sick73chevelle
Post by Limey SE on Sun Mar 24, 2013 8:35 pm
PPSSSTTTTT That Blue 74 I posted ^^^^ up there had no vinyl roof as was a 3 speed floor shift car I used to own
How it arrived to my door
Opera Windows 1974 Chevelle PHTO0025Opera Windows 1974 Chevelle NAKEDMALIGOON002
Street Cred : 92
Post by Mcarlo77 on Sun Mar 24, 2013 8:44 pm
Again...the red one in the pics I attached didn't have a vinyl top.
Street Cred : 68
Post by dynchel on Sun Mar 24, 2013 8:44 pm
Looks like my '74. Similar color blue, same slot mags, and kickstands er side pipes. I love retro.
Post by sick73chevelle on Sun Mar 24, 2013 8:50 pm
Mcarlo77 wrote:Again...the red one in the pics I attached didn't have a vinyl top.
I guess what I was trying to ask was did it come from the factory that way. Is there any sign that it was removed somewhere along the line.
sick73chevelle
sick73chevelle
Post by Limey SE on Sun Mar 24, 2013 8:51 pm
dynchel wrote:Looks like my '74. Similar color blue, same slot mags, and kickstands er side pipes. I love retro.
would still have that car if it wouldnt have been NON Saveable was loading it on a trailer and the when being pulled on with the winch the front frame folded in half OOOPPPSSSS
Street Cred : 92
Post by dynchel on Sun Mar 24, 2013 8:59 pm
Looks can be decieving, it looks really nice in the picture. The frame folded? I've never seen a g3 with frame rot, I've seen 64/72 And 78/87 with frame problems (all off their bodys rotted out) but 73/77 frames seem to hold up , even on the lake Erie shoreline of north east Ohio.
Post by Limey SE on Sun Mar 24, 2013 9:19 pm
yea the guy I had gotten it from had it in a field for more than 14 years and we all know what happens to cars that sit in a field, he hid it by undercoating in a can the front frame rails just folded in half while being pulled up on the trailer.
I have more pics of it after I parted it out and when my bro in law used a skid loader to load on the trailer to junk body the rear 1/4s in the lower sections just fell off the car LOL.
Opera Windows 1974 Chevelle Goodbyegoonie004
Opera Windows 1974 Chevelle Goodbyegoonie006
Street Cred : 92
Post by dynchel on Sun Mar 24, 2013 9:40 pm
Yeah, I know all about the undercoating over rust thing. A friend once bought a really nice (we thought) '70 cutlass rag top. Nice paint, interior, top half of motor rebuilt. Once we got it on a lift we found there was a one foot section under the door that was completely rotted away. We pulled the plastic inner fenders back and there were large holes there also. How this car didn't break in half I still don't know. He duraglassed the frame and undercoated it to hide it. Kind of a edit move, but karma caught up to him, he just recieved a 5 year prison sentance. ( bank robbery)
Post by pila on Sun Mar 24, 2013 10:25 pm
The frame rusted through in a few places on my '77 Elco, that I bought new. I scrapped it in 2009. Michigan salt takes it toll on cars.
Post by 74MonteCarlo on Mon Mar 25, 2013 9:14 am
1973, all Chevelle's had the large quarter windows. Chevelle Deluxe, Malibu, SS & Laguna.
1974, the BASE Malibu had the large windows, and the Malibu CLASSIC had the coach windows. For early 1974 production before the tooling was developed, GM put in those patch panels on the windows of the BASE Malibu body, until they got the new Malibu CLASSIC bodies made.
Post by carcass on Mon Mar 25, 2013 3:36 pm
74MonteCarlo wrote:1973, all Chevelle's had the large quarter windows. Chevelle Deluxe, Malibu, SS & Laguna.
Thanks for this info, I'm gonna check into what my car has.
carcass
carcass
