Tremec TKO 500/600 overdrive auto and other aftermarket crossmembers.
+6
carcass
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Tremec TKO 500/600 overdrive auto and other aftermarket crossmembers.
at some point I will be installing a tremec 6 spd manual in my 73 laguna chevelle, I had just assumed I would need to make my own crossmember and this thread confirms it! lazy lazy aftermarket. Thats what we get for not wanting one of those cookie cutter cars, instead of a bolt on kit we get flat metal stock and a hammer in our custom bolt on kit and no directions.
switchbiker- Donating Member
Hey, for the record, Keisler filed for bankruptcy. The TKO needs a hole cut to fit in the trans tunnel. Seriously, though...it's a set of pedals, a trans with the right input shaft, a bellhousing, clutch, flywheel, pilot bearing, and driveshaft. Biggest expense is the trans, obviously, at $2200, closer to 3 if you want the shifter in the right place. That mid shift is like $400...
brownbomber77- G3GM Member
Page 2 of 2 • 1, 2
» dual exhaust cross members custom
» Overdrive Transmission tech
» Overdrive Transmission Swap Info for GM units
Page 2 of 2
