Brake Lines
Brake Lines Empty Brake Lines
Post by driveit on Fri May 24, 2013 8:59 am
Brake lines are needing patched again or new ones installed.
Is it possible to get a flexible brake line rather than the steel?
Brake Lines Empty Re: Brake Lines
Post by dynchel on Fri May 24, 2013 9:06 am
Flexible as in rubber hose no. In my shop we use a easy bend line made by s.u.r.&r. It is rust resistant, flares easily, and is very easy to route and shape (we get it from Napa) That being said its also double the price (appx $50.00 a roll). Do you have the ability to flare lines? If not you will probably have to buy ready made lines and unions and connect them together. The lines should be
3/16 th line with standard (non bubble) fittings.
Post by thatfnthing on Fri May 24, 2013 6:12 pm
dynchel wrote:The lines should be 3/16 th line with standard (non bubble) fittings.
Meaning 45° double flares. Single or 37° won't do.
Street Cred : 58
Post by 1973 454 MONTE on Fri May 24, 2013 6:21 pm
Street Cred : 35
Post by BicknellWelding on Fri May 24, 2013 10:20 pm
I just did all the brakelines in my truck with a roll from napa. Bought a flare tool and a little hand bender, did a little research on double flaring, and just copied the shape of the lines I took out. Came out perfect, no leaks, first timer. Really simple. It was actually a fun project, I'm looking forward to doing the chevelle.
Post by ant7377 on Sat May 25, 2013 1:03 am
I hate this job with a passion. I think I need to buy a good flaring bar,crap ones make it hard ,the lines slip out of the bar when making the double flair.
Street Cred : 35
Post by BicknellWelding on Sat May 25, 2013 6:42 am
ant7377 wrote:I hate this job with a passion. I think I need to buy a good flaring bar,crap ones make it hard ,the lines slip out of the bar when making the double flair.
Same thing was happening to me. I used a pair of vise-grips to tighten the wing nuts on the bar, and it stopped the line from slipping. Im also using a cheap autozone flare tool.
Post by ant7377 on Sat May 25, 2013 11:36 am
Tried that the last time,was not succesful. Did you ever see one of those hydraulic falring tools? My bud has one and it works like a champ,he wont lend it to me,thinks I will keep it. You can flare lines right on the car if you can get to them,its effortless.
Street Cred : 35
Post by BicknellWelding on Sat May 25, 2013 11:44 am
I'd keep it
Post by ant7377 on Sat May 25, 2013 11:52 am
BicknellWelding wrote:I'd keep it
Yeah Im thinking he would be right. Id try as long as I could get away with it.
Street Cred : 35
Post by dynchel on Sat May 25, 2013 12:39 pm
That tool is $400.00....that's why I don't have one.
Post by Joe73 on Sat May 25, 2013 1:36 pm
Lines are pretty easy to do if you take your time. I've done brake lines and even flared copper lines for my boiler. I have the black and silver bender like this http://www.summitracing.com/parts/otc-6515/overview/ I dont remember the make of my flaring tool but I've never had a problem with it.
Ant, since your local, you can borrow my bending stuff if you need it.
Street Cred : 73
Post by ant7377 on Sat May 25, 2013 1:49 pm
THanks as always Joe. Might need to borrow your knowledge of flaring the damn things next time I need to.
Check this out,
http://www.eastwood.com/professional-brake-tubing-flaring-tool.html
Street Cred : 35
Post by pila on Sat May 25, 2013 11:40 pm
Seems like every car I've owned, and some I bought new, had rusty brake lines to fix eventually. My flaring tool is a cheapie, but works good. Buying the line in rolls, and the fittings in 10-packs will save money in the long run......
We who live in the so-called rust belt, are too familiar with rusty brake & fuel lines...
Post by driveit on Wed May 29, 2013 10:05 am
Thanks everyone. I may look into buying the roll of tubing as suggested and just redo all of the lines instead of another patch job.
Post by pila on Thu May 30, 2013 12:52 am
Painting the new lines seems to pro-long their life on my vehicles. The coating on new lines isn't very good at resisting rust....
Post by driveit on Thu May 30, 2013 9:21 am
Thanks for the tip. I will remember that.
