Air Compressor
Air Compressor Empty Air Compressor
Post by JB2wheeler on Wed May 29, 2013 9:41 am
I bought a Craftsmasn 120 volt oil less air compressor. It is a 3.5 HP with 25 gallon tank. Would this be enough compressor to be able to paint a car? If not, what is it enough to do. Maybe small sandblasting jobs? JB
Street Cred : 28
Air Compressor Empty Re: Air Compressor
Post by Joe73 on Wed May 29, 2013 10:29 am
Thats a pretty small compressor. Air tools are pretty much out unless you like to constantly wait for it to pump up. You need to take a look at the ratings on the unit. It will say how many cfm (cubic feet per minute) at 90 psi. There should also be a cfm rating at 40 psi. Then when you take a look at tools or spray guns or blasters, you'll know what will work. Blasters take alot of CFM just like air tools. CFM is the rating your looking for.
As for painting, and older style siphon type spray gun should work. A true HVLP (high volume low pressure) gun needs just that. High volume which is your cfm rating.
Street Cred : 75
Post by JB2wheeler on Wed May 29, 2013 7:02 pm
Thanks Joe. JB
Street Cred : 28
