Window louvers
G3GM :: G3 Tech :: Body
Page 2 of 2 Previous  1, 2
Window louvers - Page 2 Empty Re: Window louvers
Post by driveit on Wed Oct 23, 2013 11:19 am
I love the look you are going for. I plan to do mine either like that or like dynchel has soon.
Post by 77mali on Wed Oct 23, 2013 6:00 pm
pila wrote:The surround molding is anodized aluminum on mine, which is a '77 grille.
I will be looking for a better one as time goes by...
I got a 75 pot metal grille from a member here.  I really like them, I don't know if you'd need all the other components between the headlights though?  Maybe someone else who's done some swaps can say for sure, but I also have the other 75 stuff just in case.  I know my new set up has no hood ornament so that's a bit of a different look (but I like the "minimal" look).
I always assumed the surround was stainless but that would explain why they are so light & fragile (& rust prone around the nut studs & braces).
Post by Brainstain on Wed Oct 23, 2013 6:07 pm
I sold a 76 grille, aluminum trim and stacked headlight buckets to a guy that put them on a 74 that was wrecked. He said his body guy used the 74 header panel and said it swapped right over.
Brainstain
Post by dragons_lair59 on Tue Nov 26, 2013 9:55 pm
If memory correct 74-5 are a one pc and 76-7 are 2 pc and I believe every yr is slightly different on the style of grill its self
Sam
Managment
Managment
