Alternator belt ATTN Chris
Hey Chris,or anyone of you guys if you want, You dont run your smog pump on your Monte right? What belt do you use ? Do you have a part number? There must be a bad bearing in that thing and the noise is getting to me. On the big block that runs the Alt and the pump but if you take off the pulley on the smog pump the belt clears it.
Re: Alternator belt ATTN Chris
Ant, worst case, take some rope like 1/4 or 5/16 diameter and plumb it in the pulley grooves. Mark the end. Then lay it out and measure the length. Hit the parts store for a belt of that length. Pretty easy actually.
Get a belt for a 74 75 454 without smog. Try just 73 without.
Hope it helps Ant
Hope it helps Ant
1973montec- Donating Member
Wouldn't one for 73-74 truck work since they didn't have the smog crap?
don't know if SB is the same as BB But mine (alt) is 15445 Gates and other (power steering powered) is 7745 -338x Gates hope this helps ya
Thanks fellas, the truck idea popped into my head today,im going to give it a try.
Should work since brackets and all would be the same
