Need help identifing a part
2 posters
I think it's some sort of cold start valve?
Shaunaconda- G3GM Member
Re: Need help identifing a part
Are you asking about the silver cylinder with the yellow barbed fitting under the PVC pipe, or the UFO shaped, silver valve, that's lower in the picture?
Pontichev327- G3GM Enthusiast
I'm asking about the silver cylinder. A piece of the yellow fitting cracked off. If you look close you can see it stuck in the vacuum hose just under the wires. This is on my '75 Elky with the 454.
