What's it called and where can I get one? HELP!
G3GM :: G3 Tech :: Body
Post by Steelflex on Tue Sep 10, 2013 6:00 pm
Hello all, I'm working on a 75 Malibu Classic that had a full vinyl roof. The material is long gone except for some residual. There is a metal cover of some sort between the front portion of the drip rail molding and the windshield. It isn't the windshield trim. They cover the front pillar. They have a dimpled texture. One of mine on the passenger side is damaged beyond cosmetic repair. What is it? What is it called? Where can I get one?
Steelflex
Steelflex
Re: What's it called and where can I get one? HELP!
Post by Laguna Budman on Tue Sep 10, 2013 6:31 pm
A-Piller moulding. If you are putting a vinyl top back on you will need to find a textured one again. If leaving it off there are smooth ones for the cars without vinyl. You will need to go to your local salvage yard and take one off unless someone here has an extra.
Post by Steelflex on Tue Sep 10, 2013 6:44 pm
Thank you! I sure hope somebody has one!
Steelflex
Steelflex
Post by driveit on Wed Sep 11, 2013 3:27 pm
If I can go without a vinyl I am going to, but I am not sure if I can at this point I should know more in the next few weeks. I will need the ones without the vinyl pattern if I can work it out. Ill try to remember you when the time comes if you don't find something.
Post by 77mali on Wed Sep 11, 2013 8:47 pm
You can carefully sand those smooth. (carefully!!!)
Post by 1973 454 MONTE on Thu Sep 12, 2013 9:18 am
Street Cred : 35
