laguna nose fittment
G3GM :: G3 Tech :: Body
Post by bykpainter on Sat Sep 21, 2013 9:36 pm
I decided to install a laguna nose i acquired on my 74malibu......fits like crap....any imput from you guys....did they fit bad when new? Do they get worse with age? Worst is down the sides,fenders seem wider then the nose so there is quite a jump out to fenders from nose.
bykpainter
Re: laguna nose fittment
Post by Bruisr on Sun Sep 22, 2013 3:10 am
I have or had the same problem! I believe that's just the way they were designed. I have yet to see one that wasn't factory installed have the same issues. When I decide to tackle that project, I think I will see what causes the fenders to "stick out" like that and try to cut or modify to remedy that. Don't know if it is fixable, but at least I'll try. I'm like you, I can't just leave it be, it looks terrible! I believe the difference is almost 1/2 to 1/4 inch height variation in the fender to nose going down the sides of the car.
Post by Pontichev327 on Sun Sep 22, 2013 3:45 am
Have you loosened all the attatching bolts and tried moving the fenders around or are you fitting the nose on as is? That is possibly where the factory fitment comes in you were talking about. If you have already tried that and they still dont fit, you may have to look at the bracketry that hangs it to the fender/ rad support.
Post by Pontichev327 on Sun Sep 22, 2013 3:50 am
If you see a perfect one, someone has had to have done some filler work. They never were very straight on the verticle ends of the nose. That urethane was still a new process and not perfect by any means.
Post by bykpainter on Sun Sep 22, 2013 10:02 am
Thnx for the imput.its good to know mine isnt the only one....ive done paint and body my whole life so fixing it wont be too big of a deal....
bykpainter
Post by driveit on Mon Sep 23, 2013 8:38 am
Bondo! Learning to use it now.
Post by pila on Mon Sep 23, 2013 12:07 pm
If the front plastic facia has no paint on it, maybe you could use a heat gun on it & re-shape it a bit. I've had to do that with plastic bumper filler panels...
Just an idea....
Post by bykpainter on Mon Sep 23, 2013 9:14 pm
driveit wrote:Bondo!  Learning to use it now.
actually theres a product out there called panel bond,its fantastic on plastics will expand more like the bumper material and wont crack off like bondo
bykpainter
Post by bykpainter on Mon Sep 23, 2013 9:15 pm
I spent some time yesterday realigning everything..not perfect by any means but much better
bykpainter
