Polishing Aluminum
G3GM :: G3 Tech :: Body
Polishing Aluminum
Post by orange Juiced on Sun May 24, 2009 2:24 pm
So i started to receive some of the parts from my chrome guy, and he did a very good job on it. But even with the discount I got from him, it was still a big chunk of change that I could have used it on something else on the car.
I had the trim around the grill polished about 3+ years ago, which cost me $80. So to save a few buck$ i started to play around with the trim to see if i can polish it. I never cleared it and since then its gotten dulled, a few deep and low scratches. I have polished it in the past but it never looked as good as it did when i first got it. Well here's my step by step guide on how I polished, hope it helps u guys out and saves u few dollars.
The Items u will be needing for this, which u find them all at wal mart or an auto parts store.
1500 grit sand paper (to remove deep scratches)
2000 grit sand paper (for everything else)
Packet of Terry towels or detail towels
Mothers Power Ball w/drill
Mother Aluminum polish
I also used 2500 and 3000 grit sand paper, I couldn't really tell the difference when i used it and compared it to the 2000 grit sand paper.
here's the trim how it looks and close ups of some of the scratches.
After I sanded it with 2000, all the deep scratches start to show up. Here's some very deep scratches that i knocked it down with 1500.
Before
After
Then i hit it again with 2000 grit, then I used 2500 and then 3000. But I noticed that if u reuse the old 2000 grit since it worn out, it starts to polish and u can see it to start to shine. And u can skip the process of polishing it with 2500/3000 grit.
So that's how it looks after all of the sanding. At this point you're ready to start to polish and bring out the shine.. . . . I placed the camera at the center, where the two side meet and make the center point on the trim. I took the rest of the pictures like this so u can see the difference in the reflection. Also in some of the pictures its hard to distinguish where the edges of the trim are, so i added some red lines near it to help u out.
what worked for me is to polish it 2 times then wipe it off with a clean towel, repeat this several of times and ur done. When you wipe it off don't press too hard, u will start to scratch it again. Here's how it looks after the first set.
after the 2nd set.
3rd set
4th set
5th time
6th
7th
I only did half of the trim, as u can see where it starts and ends
8th
9th
10th
It does take some time and you have to clean off the power ball every so often, but the payoff is worth it.
2010 Donating Member
Street Cred: 6
View user profile
Re: Polishing Aluminum
Post by IndyG3 on Sun May 24, 2009 3:21 pm
Very nice work man! Now if only I had the motivation to go outside and do that myself...
IndyG3
Street Cred: 11
View user profile
Post by badbiscayne66 on Sun May 24, 2009 8:01 pm
WOW
badbiscayne66
Street Cred: 2
View user profile
Post by Limey SE on Sun May 24, 2009 9:13 pm
very nice job bro
Street Cred: 60
View user profile
Post by orange Juiced on Sun May 24, 2009 10:22 pm
thanks guys, at times I thought I had ruined it but u just need to be patient. Its very easy, it just time consuming. this took about 5 hours, but i was experimenting to see what gets better results and i didn't have a clue what the hell i was doing Smile Now to do the other side
Street Cred: 6
View user profile
Post by The Dude on Sun May 24, 2009 10:34 pm
Dude, you are a saint. I was just sitting back trying to figure out how I'm gonna get my new (old) wheels to shine. I'm already started working on the first one, but need to find a better way than a Dremel. Never knew those Mother's balls worked that good.
Street Cred: 48
View user profile
Post by orange Juiced on Mon May 25, 2009 3:57 pm
Rago- After i bought the power ball, I had a 2 buddies tell me there not that great. "It works good at first, but then after a while it stops working." I noticed that both of them weren't cleaning them from all the polish build up, and they were using the same ball with different chemicals.
If the wheels have no scratches, try just polishing them with the power ball and there alum polsh. My steering wheel horn button has no srcatches, so i just skipped the sanding part and polished it. came out looking good
Street Cred: 6
View user profile
Post by The Dude on Mon May 25, 2009 5:00 pm
They've been in a garage since the 70s, so there's a lot of corrosion that I need to polish out, but thanks for the tip, I'll remember to keep the ball clean & post pics when I'm done.
Street Cred: 48
View user profile
Post by wokrdan AKA BU Balls on Mon Jul 20, 2009 8:03 pm
Wait, did you do this on the chrome sections of the car??? I have this tiny bubbling coming up on my grill and am wondering if I can polish them out. Let me know.
Street Cred: 2
View user profile
Post by The Dude on Mon Jul 20, 2009 9:40 pm
The bubbling is from the chrome starting to peel. It's referred to as pitting & short of stripping the chrome, there's nothing you can do. If the chrome gets stripped, you either have to paint or re-chrome it, since it's just bare metal underneath & will rust. Sometimes small scratches in the chrome will buff out, but don't try sanding it or you will mess it up.
Street Cred: 48
View user profile
Post by orange Juiced on Tue Jul 21, 2009 10:53 pm
this works on the aluminum trim only. I haven't tried it stainless steel yet. Rago is right, u would need to rechrome it.
Since u can't clear it doing it this way, I've also been messing with some white rouge. I haven't had to much time to mess with it, also i cant seem to make it look as good as the mothers. but once i figure it out, I will post updates.
Street Cred: 6
View user profile
Post by 75 Classic on Wed Aug 18, 2010 8:55 pm
i bought trim polishing kit from eastwood and polished my aluminum radiator and it looks amazing i didnt take before and after pics but the buffing bars work wonders but in your guys opinions what would work best with stainless i am about to do my window trim and need some tips
75 Classic
Street Cred: 0
View user profile
