Header Bolts
Header Bolts
Post by ant7377 on Wed Feb 05, 2014 4:47 pm
What do you guys use? I have such a problem tightening the one above the number 8 plug (last one in back on right side).
The A/C box is in the way and I cant get a wrench on it,I have a shaved down allen bolt in there now with a cut down wrench to work it, but I can see it being trouble in the future and I want to change it.
Re: Header Bolts
Post by 77mali on Wed Feb 05, 2014 5:48 pm
I use a combo of bolts...the usual 7/16" bolt heads and a recessed allen head type that I can get in there & use an allen-key to tighten them up. The headers are a pain in the neck to work around with a wrench or socket on about half the bolt-holes- even w/ the engine out of the car-lol.
Like these-
http://howellautomotive.com/mrgasketmetricexhaustheaderandmanifoldbolts.aspx
Re: Header Bolts
Post by Joe73 on Wed Feb 05, 2014 6:31 pm
I have some stage8 bolts with the locks on them waiting for my new build. Tighten them once and forget it.
http://www.stage8.com/gm.html
Street Cred : 70
Re: Header Bolts
Post by ant7377 on Wed Feb 05, 2014 6:37 pm
77mali wrote:I use a combo of bolts...the usual 7/16" bolt heads and a recessed allen head type that I can get in there & use an allen-key to tighten them up.  The headers are a pain in the neck to work around with a wrench or socket on about half the bolt-holes- even w/ the engine out of the car-lol.
Like these-
The way that pipe is these wont go in straight.The hole is very close to the pipe,I need some thing with a very small head,makes the headers kinda suck. I might take a look at what Joe has. Keep the suggestions coming. Paul is that you in your avatar? HaHa!
Re: Header Bolts
Post by 77mali on Wed Feb 05, 2014 6:45 pm
Joe73 wrote:I have some stage8 bolts with the locks on them waiting for my new build.  Tighten them once and forget it.
Those look good...post a pic when you get them on...might try them too.  Yeah Ant, that's me in 1983 minus my buddy Tommy. afro
LOL
Re: Header Bolts
Post by dynchel on Wed Feb 05, 2014 7:11 pm
I have regular header bolts, but my car is a factory no a/c car so getting a wrench on isn't a problem.
Re: Header Bolts
Post by ant7377 on Wed Feb 05, 2014 8:54 pm
dynchel wrote:I have regular header bolts, but my car is a factory no a/c car so getting a wrench on isn't a problem.
What make of headers?
Re: Header Bolts
Post by ant7377 on Wed Feb 05, 2014 8:56 pm
LOL
Remember when they get pulled over and he tells the cop "License,yeah its on the bumper" LOL! that was from Up in smoke.
"Next Movie" was really funny too though
Re: Header Bolts
Post by dynchel on Wed Feb 05, 2014 10:02 pm
I have hooker competition headers from about 1997.
Re: Header Bolts
Post by Limey SE on Thu Feb 06, 2014 3:57 pm
I use stage 8 locking header bolts they have a allen head on them and then lock them tight
Street Cred : 89
Re: Header Bolts
Post by Joe73 on Thu Feb 06, 2014 6:14 pm
Limey wrote:I use stage 8 locking header bolts they have a allen head on them and then lock them tight
Yes, that allen key in the middle makes life much easier than trying to use a wrench.
I also like to use the soft aluminum or copper gaskets that "crush" when you tighten them. They conform to any irregularities between the head and the header flange. Much better than the composite/paper type header gaskets.
Street Cred : 70
Re: Header Bolts
Post by dynchel on Thu Feb 06, 2014 7:02 pm
I usually double up paper gaskets (two per side) glued together with rtv.
Re: Header Bolts
Post by Limey SE on Fri Feb 07, 2014 11:57 am
Stage 8 header Bolts FTW
Street Cred : 89
Re: Header Bolts
