Strange Sounds and vibrations
Page 2 of 2 Previous  1, 2
Strange Sounds and vibrations - Page 2 Empty Re: Strange Sounds and vibrations
Post by Joe73 on Tue Mar 11, 2014 7:55 pm
There is an adjustment to take out play out of the steering box. Its on top of the box. It has a screwdriver slot in the center and a locking nut to lock it down. Dont turn it much, a 1/16 to 1/8th turn should take out the play. If you go too much then your wheel wont "return" when going around a corner. If the screwdriver slot is flush with the top, or below the top, of the lock nut, then its probably time for a rebuilt unit.
Street Cred : 73
Post by dynchel on Tue Mar 11, 2014 8:02 pm
I just thought of something, do you have all four suspension braces installed?  There should be two from the core support to the fire wall, and two from the k member (under the engine) to the frame.  I have run with out these and had some weird noises. (Usually when hitting bumps , and especially pulling into drive ways)
Post by driveit on Wed Mar 12, 2014 12:46 pm
dynchel wrote:I just thought of something, do you have all four suspension  braces installed?  There should be two from the core support to the fire wall, and two from the k member (under the engine) to the frame.  I have run with out these and had some weird noises. (Usually when hitting bumps , and especially pulling into drive ways)
Do you mean the two long bars on top and two short on the bottom? If so all were removed long ago. I had to remove the bottom two so my headers would fit.
Post by dynchel on Wed Mar 12, 2014 1:02 pm
Those would be the ones. Probably not your noise, but mine made noises that those eliminated.
Post by driveit on Wed Mar 12, 2014 1:37 pm
I intentionally tried to cause the sound this morning on my way in to work and it happened again. I am really starting to think it has something to do with the cross member being loose or the tranny mount being broken.
Post by dynchel on Wed Mar 12, 2014 1:45 pm
Try to lift the rear of the trans and see if the mount is bad. You should be able to put a jack under the tail shaft (or maybe even "bench press" it)
Post by driveit on Wed Mar 12, 2014 2:28 pm
I'll check it when it warms back up.
