steering shaft
steering shaft
Post by dynchel on Tue Mar 18, 2014 8:59 am
Does anyone know what this bushing is called and where i might be able to get one?  it seens only the cotter pin is holding it in.
Re: steering shaft
Post by bracketchev1221 on Tue Mar 18, 2014 10:17 am
Yes that is just held in by the cotter pin. I would start looking for shifter bushing kits. Is this car automatic or a stick, and column or console? That ear was usually the column release for the key when the car was put into park or with a stick, sometimes reverse.
Street Cred : 14
Re: steering shaft
Post by dynchel on Tue Mar 18, 2014 11:19 am
It is a automatic with a hurst dual gate on the floor (although it was originally a column shift) Thanks for the response, now if only i don't get the deer in the headlights look from the parts store guys.
Last edited by dynchel on Tue Mar 18, 2014 11:23 am; edited 1 time in total (Reason for editing : added details)
Re: steering shaft
Post by bracketchev1221 on Tue Mar 18, 2014 11:29 am
Try the HELP stuff first. If not, just hit a TRUE hardware store. Not like home depot. A store that has drawers of bolts, nuts, all that stuff.
Street Cred : 14
Re: steering shaft
Post by 74Malibu383 on Tue Mar 18, 2014 2:49 pm
Measure the opening, and try McMaster-Carr if you can't find one anywhere local.
Re: steering shaft
Post by pila on Tue Mar 18, 2014 8:03 pm
That connection is supposed to have a rubber grommet in the arm, with the little plastic bushing inside of the grommet. I believe I bought those from OPGI, or maybe one of the other suppliers, like Dixie Monte Carlo, or....?
You need just the grommet, according to that picture. A thin washer next to the cotter pin is a good idea too...
Bill
Re: steering shaft
Post by dynchel on Tue Mar 18, 2014 8:10 pm
Thanks for the responses, it has needed this for a while & I will definitely put a washer behind it.  I just had no idea what it was called (ie  what to ask for)
Re: steering shaft
Post by 77mali on Tue Mar 18, 2014 8:12 pm
Re: steering shaft
Post by Hawk03 on Fri Mar 21, 2014 8:15 am
Found these searching for the GM part numbers in the links.
YearOne sells the bushing:
https://www.yearone.com/Product/1967-81-Firebird/9860N
GM Parts sells "sleeve kit" but doesn't say whats all included:
http://www.gmpartsdirect.com/results.cfm
Street Cred : 12
Re: steering shaft
Post by dynchel on Thu Apr 10, 2014 10:15 pm
Well I bought the eBay post (that 1973 montec posted..thanks again for that)  The kit was  nice ac delco nos in the original plastic bag (although for thirty dollars I feel a little ripped off)  While I had it apart I sandblasted the rod and painted it machinery grey.  It definitely looks better (not falling apart anymore)  Give Me Beer
Re: steering shaft
Post by driveit on Fri Apr 11, 2014 11:50 am
That does look nice.
Re: steering shaft
Post by pila on Fri Apr 11, 2014 11:36 pm
It looks " professional" which is what most folks like..... Very Happy
Re: steering shaft
Post by driveit on Sat Apr 12, 2014 9:07 am
It does. I really need to clean up my engine bay.
Re: steering shaft
Post by Hawk03 on Thu Apr 17, 2014 8:48 pm
I installed my linkage and noticed I was missing the washer/bushing (GM 1377083) that goes on the frame by the spring.
This is the cheapest one I found at $1.18 shipped. I haven't installed it yet but looks like it will fit.
http://www.ebay.com/itm/281283833773?item=281283833773&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
(Not my linkage just showing location)
Street Cred : 12
Re: steering shaft
Post by dynchel on Fri Apr 18, 2014 6:48 am
I'll have to look closer at mine, I knew I needed the obvious one above, but didn't really look closely at the bottom.  For $1.18 I may just replace it for the h3ll of it.
Re: steering shaft
Post by 77mali on Fri Apr 18, 2014 6:58 am
Interesting...I think mine was/is missing. Didn't even realize I needed it. +1 :-)
Re: steering shaft
Post by pila on Fri Apr 18, 2014 11:09 pm
It's a nylon sort of washer, which is flat on one side, and domed on the side that goes into the bracket on the frame. It should also have a flat washer on the flat side, so the spring doesn't dig into the nylon plastic.
If the linkage gets sloppy, the hole in the nylon washer may be worn oversize. I just replaced one on my partners pickup truck because it was worn oversize. Now he knows what gear he is in !
Re: steering shaft
