1976 Laguna master cylinder
I will have to replace my master cylinder, I had a generic replacement on there which worked great for years. However, it was cast iron, and looked crappy. Has anyone replaced theirs with a chrome or aluminum one? If so, then where did you purchase it?
Re: 1976 Laguna master cylinder
I got this one from them, car is still parked so i haven't actually used it yet. its not a direct fit, the mounting bracket is different.
http://www.ebay.com/itm/11-CHROME-GM-BRAKE-BOOSTER-PB011-10-YEAR-WARRANTY-/350474487427?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5199e84683
There used to be (late '90's) a 11 second '74 Monte Carlo around that the owner had adapted a later model aluminum & plastic master cylinder. I've asked here & at Chevy talk but never got any real feedback. I even researched on Napa prolink to try to find something that would work, the closest thing was a '80 elcamino, but I didn't try it so I can't say weather or not it will work.
dynchel wrote:There used to be (late '90's) a 11 second '74 Monte Carlo around that the owner had adapted a later model aluminum & plastic master cylinder. I've asked here & at Chevy talk but never got any real feedback. I even researched on Napa prolink to try to find something that would work, the closest thing was a '80 elcamino, but I didn't try it so I can't say weather or not it will work.
You mean like this?
I've seen and read about the same thing, couldn't get exact spectra for interchange, that looks like an 81 and up master, used on G/P, caminos, malibus etc
thatfnthing wrote:dynchel wrote:There used to be (late '90's) a 11 second '74 Monte Carlo around that the owner had adapted a later model aluminum & plastic master cylinder. I've asked here & at Chevy talk but never got any real feedback. I even researched on Napa prolink to try to find something that would work, the closest thing was a '80 elcamino, but I didn't try it so I can't say weather or not it will work.
You mean like this?
Yeah, that be the one.
chevellelaguna wrote:I've seen and read about the same thing, couldn't get exact spectra for interchange, that looks like an 81 and up master, used on G/P, caminos, malibus etc
Mine's from a 92 or 93 Caprice, along with the entire ABS setup (though I originally started the ABS conversion with the stock G3 M/C and swapped it and the booster later). The master cylinder and booster are a matched set, so you have to use both (the bore on the M/C is larger than the G3's) but you have to lengthen the pushrod that connects to the brake pedal by a couple inches. It's also a good idea to use the combo valve that goes along with it and mounts directly beneath. The M/C circuits (front vs. back) are reversed from the G3. The whole assembly will mount to the G3 firewall bracket, though two holes will have to be enlarged slightly. There's enough clearance to close the hood, but it will be tight.
Oh yeah, I will also say the new M/C only weighs barely 2 lbs, which is probably why drag racers like it.
I've got too many things to do on my 'Guna to reinvent the wheel with my booster/master cylinder setup. When I completely went thru my brakes, I replaced the m/c with a factory std cast iron one (always go with a new one and not a remanufactured) and painted it with Rustoleum to keep the rust at bay. Pulled and tested the original Booster, cleaned it up and painted it, also. Looks good and I'm on to the next item on the list.
Before:
After:
Before:
After:
Mcarlo77 wrote:I've got too many things to do on my 'Guna to reinvent the wheel with my booster/master cylinder setup. When I completely went thru my brakes, I replaced the m/c with a factory std cast iron one (always go with a new one and not a remanufactured) and painted it with Rustoleum to keep the rust at bay. Pulled and tested the original Booster, cleaned it up and painted it, also. Looks good and I'm on to the next item on the list.
That came out great! Did you blast the pieces first, or just sand them? How's it holding up against rust since then?
I was in the same line of thought, too much going on with the car at the moment just want to go with what I know will work, and look good. That gives me faith that even a cast iron m/c can look sharp! That may be they option for me.
The rusty master cylinder was the old one. The new one was wiped down with degreaser and painted before installed. Had to be careful to wipe any spilled brake fluid while bleeding/adding fluid to the system. Booster was sanded, wire-wheeled (I swear I am responsible for half of Dremel's wire brush business here in Mpls.), primed and painted. That was last summer and they still look the same. Granted, I didn't drive it much before storing it for the winter.
Oh, sorry, I misread it -- I thought that was the same unit, and I thought, 'Damn, that looks brand new!'
