Rear Shock Mounting Studs
Besides the Original Parts Group (OPG), does anyone know where I can find/buy a set of new rear shock mounting studs?
BBMALIBU- G3GM Member
Re: Rear Shock Mounting Studs
Are the old ones Hallowed out ? if so Take to Hardware store and get the Grade 8 and get them
Are talking the.upper bolts or the bottom doubled ended stud? I know the dorman help section has the bottom one.
Speedway Motors stops at 72 for the one Needed is this similar to what it is ?? Guess I never paid attention for I have not switched my air shocks out yet ...
http://www.speedwaymotors.com/Rear-Shock-Mounting-Stud-for-67-69-Camaro-68-72-Nova-64-72-Chevelle,118584.html
I'd have to say they are the same. When I ran those horrible 73-77 ladder bars back in the 80's I oblonged the whole and even ripped it open on the rear quite a few times.
I would just pick one of those studs up at the auto parts store and they all fit.
Ladder bars sure look cool on cars but who designed it to bolt to the shock mount for our cars?? Not a good design.
I checked the help section of every part store in my area, no luck.
This is what I was looking for:
http://www.speedwaymotors.com/Shock-Mount-Studs,5485.html
Google this part number
http://www.autozone.com/nuts-bolts-and-washers/shock-bolt-kit/help-8-pcs-universal-shock-bolt-kit/720607_0_0/
same part here. http://shop.advanceautoparts.com/p/dorman-help-shock-bolt-kit-universal-1-2-21-31001/5016940-P?searchTerm=shock+bolt
napa has them too. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Shock-Bolts/_/R-NDP6501100_0390047548
I know, I figured it should be something easy to find. Â
I went to all the stores, I even brought a sample to show them, all the employees looked at me like I was on crack.
I can look here If need be we have a lot of Parts stores that carry not the normal stuff
I bought cheap shocks and they came with the lower bolts, I know I also bought a pack of bolts as well from the chain auto parts store.
I bought air shocks for my Elco, Monroe, and those studs came with them. I suppose they didn't want the shocks mounted on questionable studs....
» Swapping rear Wheel studs to 1/2"
» Front suspension shock axis angle to vertical plane
» Cross Shaft Studs
» Cross Shaft Studs
