a few questions on engins and headers
a few questions on engins and headers Empty a few questions on engins and headers
Post by riddick75 on Tue Apr 15, 2014 6:49 pm
Ok working on my engine, assembly that is. I have a 75 El Camino that came with a 350 4 barrel carb from as near as I can figure came out of a 81 Z28 with a cast iron intake. The goal is to get it as close to being a 75 as I can as far as what went on it. Mostly just so I don't have too much of a hogepoge of parts should I need to replace something down the line. What I am wondering is how many people are running with the original intake and heads but also have headers, and what kind and size like long or short for fitment. I'm not wanting to run too much of the emissions stuff like a cat but I kinda want to use the EFE (Early Fuel Evaporation) system going to the heat riser into the intake but not sure if that will work with headers.
Also if anyone has pictures of their fully assembled engine as far as locations of what gets bolted on the front. The bottom left bolt hole in my block is broken in half and not sure if anything is supposed to bolt there. or if that would be something that would be extra.
riddick75
riddick75
Street Cred : 6
a few questions on engins and headers Empty Re: a few questions on engins and headers
Post by riddick75 on Tue Apr 15, 2014 6:53 pm
its the left side in the picture, engine upside down, opposite side of the fuel pump that has half a bolt hole that I'm curious if its needed.
a few questions on engins and headers Imgp0210
riddick75
riddick75
Street Cred : 6
Post by chevellelaguna on Tue Apr 15, 2014 7:49 pm
Sounds like a good plan to keep things stock looking. Plus, from a cost perspective that can be beneficial as well. You start getting into the high performance realm and things can get expensive and parts breakage etc.
There's  no reason why you can't use the 4bbl iron manifold and retain the heat riser with Hedders. Personal preference as to long or short style. Suggest maybe finding a used aluminum dual plane manifold (edelbrock performer) is a good one, still has the heat riser, paint it to look like a cast manifold..... It would just flow A LOT better than the restrictive iron one.
Nothing bolts to that hole in the bottom of the block.
Street Cred : 16
Post by riddick75 on Wed Apr 16, 2014 5:50 pm
Im glad nothing bolts there, when I bought it all he had on there was an alternator and power steering pump, and the one bracket was backwards on the pump. lol
riddick75
riddick75
Street Cred : 6
Post by chevellelaguna on Wed Apr 16, 2014 6:38 pm
The hole above that one is usually a thru hole to hold the fuel pump pushrod in position when you slip the fuel pump into the side of the block. Oil will leak out of that upper hole just thread in a short 1/2 long bolt in that hole. It'll be 3/8 NC threads in the block.
Street Cred : 16
