Need help with power steering.
Need help with power steering. Empty Need help with power steering.
Post by Tom77 on Fri Apr 25, 2014 9:40 am
Can I use rubber line for the low pressure return line? I have a Marsch serpentine belt system with an external reservoir and they supplied a braided hose with like a hard plastic type inside. It has leaked since I installed it. Now that I am nearing the end of installing the 383 I wanted to adress this. I am worried about the power steering fluid affecting the rubber line.
Need help with power steering. Empty Re: Need help with power steering.
Post by Joe73 on Fri Apr 25, 2014 9:49 am
I dont see why not. No pressure on the return line. Every pump Ive done only had rubber with a simple bose clamp holding it on.
Street Cred : 75
Post by dynchel on Fri Apr 25, 2014 12:20 pm
X2, rubber for the return is fine.
Post by Tom77 on Fri Apr 25, 2014 1:21 pm
Thanks thats what I assumed I just wanted someone else to say it so I will sleep tonight.
Post by 74Malibu383 on Fri Apr 25, 2014 4:41 pm
That's what I'm running too. Standard rubber -10AN return line from the reservoir to the pump. You only need to make sure the pressure side is the using the hydraulic hose.
Post by pila on Fri Apr 25, 2014 11:36 pm
The return line hose is available at most all auto parts stores.  Not sure if the hose is a particular compound of rubber though.  I just used what they sold me ......
